DIY: Sony BDP-S360 Region Free Using Harmony remote, programmed manually
Old 27-11-2011, 7:37 PM   #121
Thanks: Gave 7, Got 0
Brilliant, managed to hack a Panasonic DMP-BDT110 with my harmony 1100, thanks op!
Old 08-12-2011, 7:25 AM   #122
Thanks: Gave 1, Got 0
Thx! This worked perfectly on my BDP-S370 (Region 2) using my Harmony 555. Now i can watch my region 1 dvd's again.
Question. Does a FW-update on the BR-player undo the regionfree-hack? If so can it be applied again?
Old 08-12-2011, 1:19 PM   #123
mentm's Avatar
Thanks: Gave 80, Got 378
Firmware updates so far have not affected the hack, anything could happen in the future with new updates though. Worst case we would update our players, this could remove the hack and the hack remote codes would no longer work. Though this hasn't happened yet.
Old 05-01-2012, 10:28 AM   #124
x1n x1n is offline
Thanks! Also works for BDV-E880 using a Harmony One.
Old 05-01-2012, 9:17 PM   #125
Thanks: Gave 9, Got 28
Has anyone setup their harmony one for this, using a new harmony account, that they'd care to share?
Old 08-01-2012, 1:17 PM   #126
Thanks: Gave 57, Got 34
thanks to the original poster, works like a charm using my harmony 885 and my sony bdps185 and bdps360
Old 10-01-2012, 1:28 PM   #127
The codes have changed on the Sx80 series released in 2011 and there are already fixes for people who use One-For-All remotes. Is there any possibility to adapt the codes for the newer generations?
Old 15-01-2012, 7:08 PM   #128
Thank you SO much to the original poster, worked a treat - although have to say that the final sending of codes to the Blu Ray was remarkably anti-climactic! (Not sure what I was expecting, fireworks or something?!)
Anyway, I've now setup an account with the hack activity all set, that I'll probably never use again. If anyone wants the username for it, PM me.
Old 12-02-2012, 1:26 PM   #129
cant send you a pm because your incomming folder is full
if you or anyone else have a account with a working hack i would like to give it a try with my harmony 700 and sony bdp-s185.
Old 12-02-2012, 10:22 PM   #130
I don't know why, it only had ten messages in it and is supposed to hold up to seventy! I'll pm you the login...
Old 05-03-2012, 10:17 PM   #131
If you still have your account, I am interested!
Thank you
Old 19-03-2012, 11:21 PM   #132
Worked on Sony BDV-E780W (UK PAL) Home theatre system with Harmony ONE - Thanks Gertsen!
Originally Posted by gertsen View Post
I got tired of waiting in line for the shared login to get the settings for my harmony remote, so I started reading forums on how to program the Harmony Remote manually.
Turns out it's not as impossible as you might think, it's just not very user friendly.
I will here outline how I did it, using my Harmony 525 remote.
Since this is reconstructed partly from my memory, it may not be 100% accurate, but with alittle faith it should be possible for anyone to do the same.
From I started searching forums til now took about two hours, so it's far from impossible...
First start by creating an account using the Logitech Harmony Software.
I recommend making a new account, if using an existing account I recommend deleting all activities and devices before starting.
Start out by adding a DVD player: Sony BDG-S360
It will automaticially be named "Dvd"
Then add another identical DVD player, it will be named "Dvd 2" (No, you don't accually need to own 5 physical players!)
Make sure you finish adding each player one at a time, instead of adding all 5 in one go.
If you add all 5 players in one go, the program will change it into one single composite device, and that will not work for this purpose.
Releat 3 more times, untill you have "Dvd", "Dvd 2", "Dvd 3", "Dvd 4" and "Dvd 5" added.
The reason you need 5 DVD players created, is because the website we're going to use next can only create one command for each device, and we need 5 commands.
If you try to add more commands to one device, it will just overwrite the previously created command for that device.
So 5 players are critical!
Now go to logitechs online webinterface and login using your harmony account created earlier:
http://members.harmonyremote.com
(If it says it found a software update, just click next...)
Now go to the "Secret" Infrared page:
Logitech® Harmony® Member Web (members.HarmonyRemote.com)
Click the "Select an active device" link, and select "Dvd"
Click the "Manual" button
There are now 3 input-fields you can enter text into, click on the last one "Data Value:" (Below "Pronto") and copy/paste in the following codes:
Click Process
It will show some more codes, telling you it was successfully converted - Click Next
Now type "Hack 1" in the "Name:" field, and click the "Add" button.
It will now tell you that the command was added successfully. Click Next
Now click on the "Current Device:" link - Should say "Sony DVD (BDP-S360)"
It will show you a list of your five DVD players, click "Dvd 2"
Now Click "Manual" again, but this time enter the following codes:
Save this command as "Hack 2"
Continue untill you have created all 5 "Hack-codes", here are the final 3 sets of codes:
Sony Code 3: (Save on "Dvd 3" as "Hack 3")
Sony Code 4: (Save on "Dvd 4" as "Hack 4")
Sony Code 5: (Save on "Dvd 5" as "Hack 5")
Now you're done on the website, all five commands have been created.
Back in the Logitech Harmony software, create a new acticity, choose to manually add the activity.
Type of activity: Utility
- (Then choose "Generic Activity", the only choice available under Utility)
Now add all five DVD players to the activity (Click Add next to each of them, one at a time)
Click Save
It will now show you a list of settings, it should look like this:
Choose "Yes, but I want to add more control of options and devices for this Activity." and press Next
You should now be shown a list of actions that are to occur whenever the activity starts or stops.
It should be empty by now.
In the top half (actions that should occur when activity is started) choose "Dvd" and click "Add"
Choose "Send this infrared Command" and from the dropdown-box select "Hack 1" (Should be the last on the list). Click Next
Now select "Dvd" again, and click "Add"
This time choose Send this infrared delay: "1 second". Click next.
(This one second delay between commands is VERY important, this will NOT work without it!)
Now Select "Dvd 2", and click "Add"
Choose "Send this infrared Command" and from the dropdown-box choose "Hack 2". Click Next
Now Select "Dvd 2" again, and click "Add"
Choose Send this infrared delay: "1 second". Click next.
Now Select "Dvd 3", and click "Add"
Choose "Send this infrared Command" and from the dropdown-box choose "Hack 3". Click Next
Now Select "Dvd 3" again, and click "Add"
Now Select "Dvd 4", and click "Add"
Choose "Send this infrared Command" and from the dropdown-box choose "Hack 4". Click Next
Now Select "Dvd 4" again, and click "Add"
Now Select "Dvd 5", and click "Add"
Choose "Send this infrared Command" and from the dropdown-box choose "Hack 5". Click Next
Now Select "Dvd 5" again, and click "Add"
When done click "Save"
Choose "Yes, theese settings are correct" and click Next
Click Done
Optional: Click the "Settings" button next to the newly created "General Acticity" and choose "Rename General Activity" and rename it to "Sony Hack!" or whatever....
Click "Update remote" and wait for the remote to be programmed.
now you're done programming the remote!
Now go and turn on your TV and the Sony BDP-S360.
Wait untill you see the home screen on your TV, and make sure there are no discs in the drive, and that the drive is closed.
Now aim the remote at the DVD player, I recommend keeping a distance of about two meters, you be the judge of that..
Now press the new activity button, should be named either "General Activity" or "Sony Hack!" or whatever you called it.
Keep aiming the remote at the DVD player for at least 10-15 seconds.
The remote will blink alittle while it's working...
When the remote stops working, the DVD player should start blinking the blue light above the disc-drive - this means everything worked.
Now try inserting a DVD with a region-code you couldn't play before - it should now play!
Once you are satisfied everything is ok, turn the player off, and disconnect the power.
Then plug back the power and everything is good now.
(This last step is to stop the blue light from blinking while the player is turned on...)
Enjoy region free DVD playback on your Sony BDP-S360!
Disclaimer:
Sources:
Old 20-03-2012, 12:38 AM   #133
This region free hack also worked with my Sony BDP-S185 using the Logitech Harmony 785.
Tips for beginners,
- If the logitech website asks you for a software update, just ignore it. If you think you're running the latest software, you are!
- When you've added "Hack 1" and you go to add "Hack 2", you will most probably get an error. I assume this is because the Logitech web software doesn't recognise you're on the next device (ie. DVD2 rather than DVD). If I pressed "back" (or reloaded the original page listed in the first post), it remembered "Hack 1" but wouldn't give me the error.
Does anyone know if this hack is a one-shot, or does it need to be re-done each time? I don't have any foreign media to test it with, as i'm doing the hack for someone else - and I don't have ready access to their media either.
DeWalt
Old 20-03-2012, 8:39 AM   #134
mentm's Avatar
So far the hack has been permanent, anything could happen in the future with firmware updates etc
The only way of knowing it has worked without an appropriate disc is the blue flashing light you get at the end
Old 21-03-2012, 8:47 AM   #135
Thanks mentm.
I will avoid firmware update
Thanks to everyone for this great post. It's one of the harder software hacks i've done to a COTS piece of hardware
DeWalt
Old 01-06-2012, 1:10 AM   #136
Limited Member
Thanks: Gave 27, Got 129
Thanks to the OP!
This hack also works on a Sony BDP-S390
shotokan101 (01-06-2012)
Old 11-06-2012, 8:17 PM   #137
Thanks: Gave 2, Got 1
also worked with a sony BDP-S480 and Harmony One remote
Thanks to the original poster, very clear instructions
Old 19-06-2012, 2:45 PM   #138
Thanks: Gave 2, Got 5
I am trying to get this to work with my Panny DMP-BD45 and a Harmony 600.
Anyone know a way that I can add the 10 different codes for the Panny when I only have space for 5 devices?
Old 27-06-2012, 4:09 PM   #139
Limited Member
Thanks: Gave 25, Got 20
Worked perfectly on a Harmony 525 and an R2 Sony BDP-S780 - good work !
Old 23-09-2012, 9:21 PM   #140
From what I've read it seems the same procedure works for numerous Sony players. Will it also work with a BDP-S590 (region 2)?
And do I need that specific Logitech remote control or will just about any universal remote on the market do? I haven't bought any such remote yet though.
Old 25-09-2012, 2:37 PM   #141
Would this work for Pioneer BDP-150?
As I understood this approach should also work for a Pioneer BDP-140 as this is similar to the ones listed.
Now I just bought a Pioneer BDP-150. I think this is not so much different from the BDP-140 either. So my question would this also work for my player?
Thanks!!
Old 13-10-2012, 10:05 PM   #142
Also works for a Sony BDP-S390. Region free!
Old 24-11-2012, 6:53 PM   #143
Scotty Pro's Avatar
Thanks: Gave 32, Got 62
Just to say thanks to gertsen
I was contemplating buying an Oppo 93 for region free DVD playback. No need to now. Used my Harmony as per instructions and it works on my Sony 570 with latest firmware.
There is one little thing though, when I play a DVD from USA the sound defaults to Stereo through my system (Marantz SR 5006) and yet all the Blus play DD or DTS and the Region 2 DVD's also decode the correct sound format, is this a known issue with the hack ?
TBH its no big deal since I can just switch the amp to DD, was just wondering if it was something I have done wrong.
Old 29-12-2012, 6:01 PM   #144
marktaberham's Avatar
Thanks: Gave 3, Got 2
Old-ish thread I know, but I wanted to say thanks to Gertsen - his outlined hack worked a treat on my Sony BDP-S480 today . Less than 1/2 an hour to sort out making the BDP-S480 region free with the codes and a Harmony 525.
Been meaning to get round to doing this since I bought the player a year ago!
Merry Xmas and a Happy New Year!
Old 29-12-2012, 6:34 PM   #145
Scotty Pro's Avatar
Do you get DD from the discs or stereo like me.
Old 29-12-2012, 8:34 PM   #146
Autopilot's Avatar
Thanks: Gave 587, Got 868
Does anyone know if there is a way to make the bdp-s360 region free for bluray disks?
Old 29-12-2012, 10:17 PM   #147
mentm's Avatar
I get all the audio formats on the discs on mine
Multi region bluray would require a hardware mod if available.
Old 03-01-2013, 6:36 AM   #148
Hi. I have a Panasonic DMP-BD77. It requires 10 codes to perform the hack. I have a Harmony 700 remote. It is limited to 5 devices so I can't use Gersten's method. Every time I try Iserlohn's method it only keeps the last code I entered all the previous ones are lost.
Does anyone know a way around this?
Old 04-03-2013, 4:34 PM   #149
Thanks: Gave 3, Got 1
This worked with my Sony BDPS590!! Fantastic!!
Old 30-03-2013, 3:00 AM   #150
sapichu's Avatar
Bdp-s590
Some years ago I make my BDP-S350 work, but I couldn´t make my S590, how did you did it?
