DIY: Sony BDP-S360 Region Free Using Harmony remote, programmed manually
Old 28-09-2010, 6:11 AM   #61
Originally Posted by ah75 View Post
Thanks gertsen - your steps worked on a Sony DAV-IS10 with a Harmony 895 remote!
(btw I didn't need to unplug (no flashing blue light anyway), but it was important to power down the device using the original remote after using the hack on the Harmony)
Hi I tried to hack DAV-IS10 (bought in USA) using Harmony 510, but it did not work.
Do you know why?
Old 28-09-2010, 6:24 AM   #62
Hey Gersten,
I could not find a dvd player in device dropdown and hence chose "Sony Mini System (DVD, CD, Radio)".
It went well until i added all 5 players to General Activity as you mentioned, but I was asked to select an input for each player and chose "I don't need to set the input on my Sony Mini System (DVD, CD, Radio)" for all players.
I was able to create hack1 to hack5 and assign them to respective players as well. When I turned devices on and pressed General Activity, remote blinked only for 2 - 3 seconds and displayed sucess message.
But when i inserted dvd, it gave me a message Cannot play
Playback prohibited by Area limitations.
so it did not work for me.
Can anyone help?
Old 29-09-2010, 5:13 AM   #63
didnt work for me. used harmony 510 on DAV-IS10
Old 29-09-2010, 11:54 AM   #64
Preeminent Member
shotokan101's Avatar
Thanks: Gave 6,504, Got 9,622
Originally Posted by dakugabbar View Post
Hey Gersten,
Can anyone help?
AFAIK the hack codes ONLY work for PAL players....
Jim
Old 03-10-2010, 2:52 PM   #65
Fatti's Avatar
Thanks: Gave 30, Got 38
Many thanks gertsen, picked up a 525 from Richer Sounds yesterday, followed the instructions and my BDP-S370 is now region free. Took around 20 minutes to pop everthing in, but well worth the effort....cheers
Old 09-10-2010, 12:50 AM   #66
Thanks: Gave 1, Got 1
Well I registered just to say thank you. I have a Sony BDP-S570 just purchased this week from Amazon and have had a Harmony 525 for a few years now. I followed the instructions (original 5 dvd instances - I couldn't get the computer one to work) and BAM multi-region joy ensued.
I will have one happy son in the morning who can watch Finding Nemo again after Daddy sold the DVD player to get a blu-ray that didn't play all the DVDs.
This is a great forum. Cheers
Goblin (17-10-2010)
Old 21-10-2010, 10:46 PM   #67
Thanks: Gave 6, Got 38
Just another confirmation that this technique has worked successfully on a Sony S350, S370 and S570 (no, I don't know why I've bought three Blu-Ray players in the space of a year).
Old 28-10-2010, 8:41 PM   #68
Worked on My Sony BDP-S350 & BDP-S370 using Harmony 555 remote.
Old 06-11-2010, 5:38 PM   #69
Smile
Worked on my BDP-S370 using a Harmony 555. When trying to run the sequence as a Macro the remote appeared to spit it out in one go with no delays and all that happened was that the player turned off. Following a previous suggestion I tried using sending the code manually be selecting one device at a time and then the Hack softkey. Worked fine.
Old 27-11-2010, 3:53 AM   #70
Many Many thanks! I used this process together with codes for Panasonic DMP-BD65 (which requires 10 devices instead of 5) and that worked a charm... the second time.
Firt try didn't work. 2nd try I left the tray open as I'd read that for some other players. I also waited longer after it was done before doing anything else. It eventually went back to the menu where I'd left it before I tried a DVD.
The codes were here:
Blu-Ray Player Multi-Region Hex Codes
Old 05-12-2010, 2:08 PM   #71
burjor's Avatar
Thanks: Gave 1, Got 0
will this also make the bluray multi region or only dvd?
thanks..
Old 05-12-2010, 4:59 PM   #72
Preeminent Member
thanks..
Just DVD - BR needs H/W Mod...
JIm
Old 05-12-2010, 6:26 PM   #73
burjor's Avatar
JIm
is there a mod for this player to make it region free for bluray discs?
thanks..
Old 05-12-2010, 6:46 PM   #74
Preeminent Member
thanks..
Yes but expensive to get done and difficult to do DIY :-
ICOS HD mod chip + BDP-S360
Jim
Old 06-12-2010, 11:08 AM   #75
Limited Member
Thanks: Gave 17, Got 1
This worked on my BDV-E370. Thank you!
Old 07-12-2010, 9:59 PM   #76
Uridium's Avatar
Thanks: Gave 556, Got 1,870
Worked perfectly on a BDP-S360 I hacked for a friend. thanks.
Old 08-12-2010, 9:55 AM   #77
Sony BDP-S370 (USA Model)
Does the harmony remote hack work on the US version of the Sony BDP-S370 or just the PAL version?
Old 08-12-2010, 10:04 AM   #78
Preeminent Member
Just PAL
Jim
Old 10-12-2010, 5:08 PM   #79
Thanks for this, i have managed to do my Sony 370 with the 555 remote.
Old 13-12-2010, 10:24 AM   #80
It worked on my PAL Sony BDP-S760. Many thanks
Old 26-12-2010, 11:29 PM   #81
imnotrich's Avatar
Thanks: Gave 64, Got 63
Top instructions thanks very much, got my bro's 370 player working with the a harmony 555 remote to do the hack, no issues whatsoever.
Old 01-01-2011, 8:37 PM   #82
Thanks: Gave 39, Got 37
Wasn't sure where to post this, but you can use this method without needing to buy a remote control if your laptop/PC has an IRDA (infra red) port by following the instructions in this link Making the Sony DVP-NS705V multi-region
Worked fine for me, and saved me having to buy a remote.
Old 09-01-2011, 3:55 PM   #83
Originally Posted by ritschy View Post
I can confirm it's working for German BDP S370 with Harmony 515. Thanks sooo much!!!!
I tried the same Hack on a German BDP S-470 and can confirm that it also works.
Old 09-01-2011, 7:55 PM   #84
Just letting you know: Update to M04.R.735 does not affect codefree hack (for BDP S-470).
Old 18-01-2011, 12:25 AM   #85
fremantle74's Avatar
Thanks: Gave 6, Got 0
Great, thanks. Just got it to wok with my Sony BDP-570.
Old 01-02-2011, 7:19 AM   #86
there was a previous thread people sharing there harmony remote, im trying to get my BDP 360 to play DVDS other then region 1 I would really like to get this player hacked anyone that could give me any help i would greatly appreciate!
i need to know what i need to buy (what kind of remote) etc.. then do i have to program the remote?
etc..etc..
anyone could give me a hand with this i would greatly appreciate!!!
thanks
josh m
Old 01-02-2011, 11:19 PM   #87
works with BDP 370 and harmony 515
Gertsen dug around the forums this evening having picked up the 370 today. Having read your post carefully I realised I had a 515 from a while back (cheap play.com deal) and programmed it with little technical knowledge. It seems a lot more complicated than it actually is and everything worked first time. I am mega chuffed as I have loads of R1 stuff my kids watch. Excellent post and much appreciated thanks for this !
Old 02-02-2011, 6:17 PM   #88
mentm's Avatar
Thanks: Gave 80, Got 378
etc..etc..
thanks
josh m
hack doesn't work with region 1 players.
Old 10-02-2011, 2:11 PM   #89
Is it a lost cause to try the Harmony hack on a Sony BDV-e800w? Are there any risks?
Old 10-02-2011, 6:00 PM   #90
mentm's Avatar
this is a generic hack and seems to work with all recent sony players, so it will probably work. It definitely works with another all in one the sony bdv e370.
Risk? i have heard of someone screwing up their player but they used a one for all remote and i suspect they had programmed in the wrong code number. I would say this is less likely using the discrete codes here which worked for me. Alternatively buy or rent a pre-programmed remote.
