Sony DVP-SR90 Multi Region Free Hack
| Post Reply |
| | #1 |
| New Member | Sony DVP-SR90 Multi Region Free Hack
Having been searching for sometime, I finally have a working region free hack for this compact little player. This works 100% successfully for the Sony SR90 DVD player (DVP-SR90 / DVP-SR90B). In order for this hack to work, you will have to send infra-red codes to your player using a OneForAll remote. The steps to prepare the remote with the required "service codes" can be found below. I have successfully used this hack with a OneForAll 4 (URC 7740) and OneForAll 5 Digital (URC 7555). To be honest, most recent OneForAll remotes should be more than capable of performing this hack if they support setup code 0533. You could look around for a cheap remote and check the manual on the OneForAll website to confirm code 0533 is listed under the DVD section of the manual. /// Preping the remote /// 1. Firstly, you will need to prepare your OneForAll remote with the service codes it is going to send to the DVD player to unlock it. Follow these steps - * Press the DVD button on the remote * Hold down the Magic button until the unit performs a double LED flash * Configure your remote by entering the code 0 5 3 3 2. Now verify that both the official Sony remote control and your OneForAll remote control can power your DVD player on and off. 3. Program your OneForAll remote with the following instructions: * Hold down the Magic button until the unit performs a double LED flash * Configure your remote using the code 9 9 4 (or 0 0 9 9 4 if your remote only accepts 5 digit codes) * Press the Magic button once * Configure your remote using the code 1 8 9 (or 0 0 1 8 9 if your remote only accepts 5 digit codes) * Press the number 1 button once, a double LED flash should occur 4. Program your OneForAll remote with the following instructions: * Hold down the Magic button until the unit performs a double LED flash * Configure your remote using the code 9 9 4 (or 0 0 9 9 4 if your remote only accepts 5 digit codes) * Press the Magic button once * Configure your remote using the code 2 5 5 (or 0 0 2 5 5 if your remote only accepts 5 digit codes) * Press the number 2 button once, a double LED flash should occur 5. Program your OneForAll remote with the following instructions: * Hold down the Magic button until the unit performs a double LED flash * Configure your remote using the code 9 9 4 (or 0 0 9 9 4 if your remote only accepts 5 digit codes) * Press the Magic button once * Configure your remote using the code 0 9 5 (or 0 0 0 9 5 if your remote only accepts 5 digit codes) * Press the number 3 button once, a double LED flash should occur 6. Program your OneForAll remote with the following instructions: * Hold down the Magic button until the unit performs a double LED flash * Configure your remote using the code 9 9 4 (or 0 0 9 9 4 if your remote only accepts 5 digit codes) * Press the Magic button once * Configure your remote using the code 2 2 1 (or 0 0 2 2 1 if your remote only accepts 5 digit codes) * Press the number 4 button once, a double LED flash should occur 7. Program your OneForAll remote with the following instructions: * Hold down the Magic button until the unit performs a double LED flash * Configure your remote using the code 9 9 4 (or 0 0 9 9 4 if your remote only accepts 5 digit codes) * Press the Magic button once * Configure your remote using the code 0 7 9 (or 0 0 0 7 9 if your remote only accepts 5 digit codes) * Press the number 5 button once, a double LED flash should occur 8. Ensure there is no disc in your DVD player and place the unit into standby. 9. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time. 10. The DVD Player will now power up. 11. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control again, in order, one at a time. 12. Your DVD player should return itself to standby mode. 13. Next time your DVD player is powered up you will be region free! 14. Remove the batteries for a significant period of time to wipe the programmed codes on your OneForAll remote. You are now good to go! |
| Quote |
| Advert Log in or sign up to remove |
| | #2 |
| New Member | Sony DVP-SR90 w / One-For-All URC-7140
Thnx for the original post! Here is a terrific update: You can use the URC-7140 (16.98GBP) w/ the Sony DVP-SR90 (34.98GBP) FLIPPIN' AWESOME!!!!!!!! do the following for this player / remote combo: FIRST Press the MODE key on the One for All remote control until DVD is highlighted. Press and hold MAGIC until you notice two flashes on the controller, and then type 0533. Controller will flash twice again. NEXT 1) Turn off SONY DVP-SR90 with the POWER button on the controller 2) Press the MODE Key on the One for all remote until DVD is highlighted. 3) Press and hold Magic Key until you see two blue blinks 4) Type 994 5) Press the Magic key 6) Type 00189 7) Type 1 8) Press Magic. Two blue flashes on the remote. 9) Press and hold Magic Key until you see two blue blinks 10) Type 994 11) Press the Magic key 12) Type 00225 13) Type 2 14) Press Magic. Two blue flashes on the remote. 15) Press and hold Magic Key until you see two blue blinks 16) Type 994 17) Press the Magic key 18) Type 00095 19) Type 3 20) Press Magic. Two blue flashes on the remote. 21) Press and hold Magic Key until you see two blue blinks 22) Type 994 23) Press the Magic key 24) Type 00221 25) Type 4 26) Press Magic. Two blue flashes on the remote. 27) Press and hold Magic Key until you see two blue blinks 28) Type 994 29) Press the Magic key 30) Type 00079 31) Type 5 32) Press Magic. Two blue flashes on the remote. note: as shown in step 1) Make sure your player in standby mode 33) Press keys 1, 2, 3, 4, 5 in sequence on the One-For-All remote. player displays 'oh' in the blue display and the player comes on 34) Type keys 1 2 3 4 5 in sequence and the player goes off. Unplug the Sony player from the power source for 5 seconds Plug back in and your player is now region free. |
| Quote |
| | #3 |
| New Member | fleetchief
I was unable to obtain either a URC 7740 or a URC7555, was able to get a URC-7556 which supports code 0533. However, this unit does not seem to give a 'double flash' after numbers, 1,2,3,4,5, are selected at each stage of preparation. Any ideas please? Many thanks |
| Quote |
| | #4 |
| New Member |
Thank you - the hack in the OPs post worked for me using the URC-7960 One for All remote on the Sony DVP-SR90 and then on the Sony BDP-S570B too. I think there is a mistake in ocolocd's post though - the code for key 2 is 00255 and not 00225. That tripped me up for a while! The set up bit and flashes were a bit different on my remote which confused me for a long time . This is how it worked for me:1 Hold Magic until the light around OK flashes twice 2 Select dvd using the arrows on the top of the remote 3 Type 0533 - I think the light around OK flashed twice. The remote then works to power the DVP on and off. Next: 1 Hold Magic (blink blink) 2 994 (blink blink) 3 Press Magic 4 001891 (blink blink) 1 Hold Magic (blink blink) 2 994 (blink blink) 3 Press Magic 4 002552 (blink blink) 1 Hold Magic (blink blink) 2 994 (blink blink) 3 Press Magic 4 000953 (blink blink) 1 Hold Magic (blink blink) 2 994 (blink blink) 3 Press Magic 4 002214 (blink blink) 1 Hold Magic (blink blink) 2 994 (blink blink) 3 Press Magic 4 000795 (blink blink) Then from standby with no DVD loaded: 1 Press 1, 2, 3, 4, 5 and the DVP turns on 2 Press 1, 2, 3, 4, 5 and the DVP turns off. Now works for R1. After I'd done the DVP-SR90 I took the control through to my Sony BDP-S570B and did this: 1 turn it on with Sony remote (the One for All doesn't work) 2 press 1, 2, 3, 4, 5 on the One for All remote (the light in the middle of the BDP starts flashing here) 3 turn it off with the Sony remote and that now plays region 1 dvds too ![]() I now feel all ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thank you btw - I didn't buy any particular All for One remote - this seems to work for all of them? Maybe I was just lucky. |
| Quote |
| Post Reply |
LinkBack URL
About LinkBacks
