| Re: Sansung BD-7200 unlock code?
Hi Mike,
I have spent some time looking for that hack. The closest I have come are the following 2 variants. I have not mange to make it work on my player, but apparently some people have had success.
Let me know if it works for you - in which case I guess I just need to persist.
Good Luck, Christian
SAMSUNG HTDL/M HOME THEATRE SYSTEMS
Power On with empty tray (No Disc will be displayed in the DVD control panel)
Press the Enter button on your remote control
Press the buttons 8, 4, 2, 6, 9 and Enter button on your remote control
Tray will Open automatically
Close the tray on the DVD player
After 15 seconds have elapsed, power Off your player (switch the unit to stand-by mode) and then power On your player
Finished
HT- Q series Hack
1. Remove Disc from Tray.
2. Switch Off Player
3. Wait 30 Seconds, Then Reconnect Mains.
4. Turn On player with Remote Control. Wait for player to Finish Loading and Display 'No Disc'.
5. Press Enter on Remote Control. (There will be No On-Screen Response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be No On-screen Response.)
7. Press Enter on the Remote Control. Player will Automatically Turn Off.
8. Turn Player On.
9. Open Tray
10.Close tray.
11.Turn Player Off then On Again.
12.Player is Now Region Free.
