When will the Harmony Remote Multiregion DVD Hack for Pioneer thread be re-opened?
Old 03-11-2009, 2:56 PM   #1
Thanks: Gave 49, Got 123
Hi All,
I have a Pioneer BDP-51FD blu ray deck and was looking to make it region free for DVD.
It seems i missed the boat as the thread created to do this (called Harmony Remote Multiregion DVD Hack for Panasonic, Pioneer & Sony Blu-ray's Part 6) closed down at the start of September:
http://www.avforums.com/forums/blu-r...-part-6-a.html
I was just wondering if there is any chance of this thread being re-opened?
Old 04-11-2009, 8:31 PM   #2
Re: When will the Harmony Remote Multiregion DVD Hack for Pioneer thread be re-opened
Mods, any idea's when this will be open again?
Old 09-11-2009, 2:37 PM   #3
Anybody?
Old 18-11-2009, 12:17 PM   #4
Iron Man 2's Avatar
4,407, Level: 15
Points: 4,407, Level: 15 Points: 4,407, Level: 15 Points: 4,407, Level: 15
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 109, Got 62
Originally Posted by richribbon09 View Post
Anybody?
I emailed Harmony with the codes for the pansonic BD35. This is the response I got this morning:-
The requested codes have been added into your account for your Blu-Ray player. There are two options available to carry out the sequence that you are requesting, if you need this to be done at the beginning or end of an activity, you can add these commands one after another and have the Harmony send them out once the activity is started or when it is ending.
If you want to be able to manually send this string of commands with one button press, you will not be able to do so. You will need to create an activity sequence using the first 5 commands, and then create another sequence using the next 5 commands. With the sequences, you will not be able to determine the amount of time the remote pauses in between each command that is sent out. With the custom activity starting an sending actions, you can apply a pause in between each command. I have provided the FAQ links for both of these options below;
Answer Title: Mapping a Sequence of commands to a single button on the remote.
Answer Link: Answer
Answer Title: Adding commands to be sent at the start or end of an Activity for a Harmony Remote
Answer Link: Answer
Old 18-11-2009, 9:04 PM   #5
Iron Man 2's Avatar
4,407, Level: 15
Activity: 0.8%
Checked the harmony account tonight and sure enough the panasonic player has remote signals for each of the 10 codes. Created a generic activity with each signal sent and 0.5 sec gap and it works
Old 22-11-2009, 6:25 AM   #6
56,081, Level: 57
Points: 56,081, Level: 57 Points: 56,081, Level: 57 Points: 56,081, Level: 57
Activity: 8.8%
Activity: 8.8% Activity: 8.8% Activity: 8.8%
Thanks: Gave 519, Got 1,459
People are working on getting the Harmony thread up and running again. No definite timsecale though I'm afraid.
