TEAC TC-550D Region Hack
Old 24-10-2009, 3:39 AM   #1
1,404, Level: 8
Points: 1,404, Level: 8 Points: 1,404, Level: 8 Points: 1,404, Level: 8
I have recently bought a TEAC TC-550D player. Does anyone have a region hack for this one. Most welcome!
Cheers!
Old 24-10-2009, 6:33 AM   #2
24 P's Avatar
10,331, Level: 24
Points: 10,331, Level: 24 Points: 10,331, Level: 24 Points: 10,331, Level: 24
Thanks: Gave 141, Got 280
Re: TEAC TC-550D Region Hack
Unlock Teac DVD players
Try here, no guarantees though..
Old 24-10-2009, 10:44 AM   #3
1,404, Level: 8
Thanks for the post, didn't solve it unfortunately .
Old 26-10-2009, 5:19 AM   #4
1,404, Level: 8
After trying about every code that was posted online, I finally found one that works for my TEAC TC-550D player. Hope others will find this resourceful too:
1.Press DVD "OPEN/CLOSE" key (RC (remote Control) or main unit) to open the DVD tray (note:if no disc on tray,then you have not to open it);
2.Press RC "SETUP" key to enter DVD system setup menu;
3.Press RC "direction "key to hightlight the forth item "PREFERENCE PAGE" (not entering the sub-item );
4.Press RC numeric key sequentially 811502(enter code,no display on TV);
5.Press RC "down direction" or "up direction" key to change REGION CODE,"0" is all code.
6.Press RC "ENTER" key to confirm.
7.Press RC "SETUP" key to exit DVD system setup menu.
Source: Teac DR-H300 region code - DVD Players and Blu-ray Players region codes - VideoHelp.com
