Sony DVD Player/Recorder. Update to play Region 1. ?
Old 24-09-2009, 2:48 PM   #1
2,271, Level: 11
Points: 2,271, Level: 11 Points: 2,271, Level: 11 Points: 2,271, Level: 11
Thanks: Gave 3, Got 0
I have a Sony DVD Hardrive Player/Recorder. RDR-HXD560. I would like to upgrade it to play Region 1 DVD's.
My Question:- Is this possible? I have no technical ability other than to press buttons and follow simple instructions. So? If it is possible. Can I do it myself or will it need taking to an expert?
Thanks for any help you can give.
Geoff ( The UK)
Old 24-09-2009, 3:46 PM   #2
skk3's Avatar
6,485, Level: 19
Points: 6,485, Level: 19 Points: 6,485, Level: 19 Points: 6,485, Level: 19
Activity: 15.5%
Activity: 15.5% Activity: 15.5% Activity: 15.5%
Thanks: Gave 68, Got 101
re: Sony DVD Player/Recorder. Update to play Region 1. ?
Originally Posted by geoffring View Post
I have a Soni DVD Hardrive Player/Recorder. RDR-HXD560. I would like to upgrade it to play Region 1 DVD's.
Geoff ( The UK)
Do you mean HXD-650?
Check here for a possible solution
Old 24-09-2009, 6:11 PM   #3
2,271, Level: 11
Re: Sony DVD Player/Recorder. Update to play Region 1. ?
it is ..............560.
Thanks.
Old 24-09-2009, 8:50 PM   #4
skk3's Avatar
6,485, Level: 19
Activity: 15.5%
Thanks.
OK - the website should still help...
