Toshiba SD290
Old 06-09-2009, 11:55 AM   #1
Donali's Avatar
4,622, Level: 16
Points: 4,622, Level: 16 Points: 4,622, Level: 16 Points: 4,622, Level: 16
Activity: 5.1%
Activity: 5.1% Activity: 5.1% Activity: 5.1%
Thanks: Gave 12, Got 63
Toshiba SD290
This is the same hack as that used for the SD190.
- Power On
- Open Tray
- Press 9879 0 (0 stands for Multiregion, you may press buttons 1 to 6 to choose a specific region)
- A Message appears stating that "The Reg.No was changed to region 0"
Regards
Don
TarPot (30-09-2009)
Old 14-09-2009, 10:17 PM   #2
2,247, Level: 10
Points: 2,247, Level: 10 Points: 2,247, Level: 10 Points: 2,247, Level: 10
Re: Toshiba SD290
Works a treat - top tip!
Old 22-12-2009, 12:53 PM   #3
1,250, Level: 7
Points: 1,250, Level: 7 Points: 1,250, Level: 7 Points: 1,250, Level: 7
This worked perfectly for me. However I did not get the "message".
Actually I did it slightly differently
- Turn on at plug
- open draw
- on remote type 98790 <OK>
- draw will close.
it is now all region enabled.
Old 28-12-2009, 9:48 PM   #4
1,237, Level: 7
Points: 1,237, Level: 7 Points: 1,237, Level: 7 Points: 1,237, Level: 7
Sd290 hack
Hi, I have tried the hacks described on my Toshiba SD290 and can not get them to work.
Kind Regards
John1961
