Hack for LG TV/DVD Combo 26LG4000
Old 21-08-2009, 5:26 PM   #1
mjcairney's Avatar
13,043, Level: 27
Points: 13,043, Level: 27 Points: 13,043, Level: 27 Points: 13,043, Level: 27
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 195, Got 526
If anyone has an LG 26LG4000 TV/DVD Combo and needs to make it multi-region, here's how to do it:
"With the TV on, press the menu buttons on both the TV and remote at the same time for approximately 5 seconds - the service menu comes up, use the down arrow key to get to region setting - it's currently set to EU/Jpn - and use the right arrow key to bring up World Wide - then switch TV off and back on - job done"
However, do bear in mind that you're in the service menu where, no doubt, you could do some damage, so take care and don't do anything stupid.
Cheers,
Martin.
