Originally Posted by Omegac Yep, basically they flick a switch their end and you'll know once its active as the gprs indicator on your phone will capitalise and show GPRS (or gsm to GSM, 3g to 3G)
With Orange it is just a fiver for both, I use it on T-Mobile, as although it's a tenner, it enables me to switch my sim into my iPhone occasionally, as one thing to be aware of, with Orange (and O2) if you use a BB provisioned sim in a non BB phone and use the internet, you'll get charged for data usage. |
Thanks for letting me know what to look out for! I'm glad it's not as complicated as I thought.
I think my iPhone is locked to 02 so I wouldn't be able to I suppose, though originally I had thought about trying to get it so I could switch back forth. I'll probably be better off as I am, and I plan to use each for different things. I don't have half the features on the iPhone switched on, because of the battery so I plan to use those with this Blackberry and take it around with me. The iPhone will be a bit of fun, I'll get some use from the apps from time to time.
Hopefully it should be here tomorrow, and I'll get everything set up smoothly. Thanks for all the help, I really appreciate it.
