Motorised Dish Installation Special Offer
Thread Closed
Old 01-05-2009, 3:23 PM   #1
6,595, Level: 19
Points: 6,595, Level: 19 Points: 6,595, Level: 19 Points: 6,595, Level: 19
Thanks: Gave 12, Got 95
For this month only
Exclusive to av forum menbers. I am offering motorised 80cm installed with Technomate TM3100 FTA reciever for £300 fully installed
www.1install.com kieran@1install.com
Old 01-05-2009, 5:04 PM   #2
6,909, Level: 19
Points: 6,909, Level: 19 Points: 6,909, Level: 19 Points: 6,909, Level: 19
Thanks: Gave 87, Got 152
Re: Motorised Dish Installation Special Offer
How much would install be as a standard if I got the motor, lnb, dish and receiver already. Would just want t&k brackets, pole, cable (to be installed into two rooms as would be twin lnb) and f-plugs...
Old 01-05-2009, 5:11 PM   #3
6,595, Level: 19
Hi please email me your postcode and what reciever you are going to buy and if you want me to load any software onto it for you (including key files or softcam files) or patches, kieran@1install.com
Old 01-05-2009, 5:38 PM   #4
Founder
Stuart Wright's Avatar
146,944, Level: 92
Points: 146,944, Level: 92 Points: 146,944, Level: 92 Points: 146,944, Level: 92
Activity: 18.2%
Activity: 18.2% Activity: 18.2% Activity: 18.2%
Thanks: Gave 902, Got 4,628
Please post bargains in the bargains forums and follow the rules for the bargain forums.
Thread Closed
