Samsung 22 Inch 1080P LCD TV Offer
Old 18-11-2009, 10:31 PM   #1
1,691, Level: 9
Points: 1,691, Level: 9 Points: 1,691, Level: 9 Points: 1,691, Level: 9
We have a few open box Samsung examples with 12 months warranty to clear.
  • Key Features:
  • 22 inch widescreen LCD HD TV
  • Stylish Black Rose design to fit in with any environment
  • Integrated DTV tuner and PC Monitor
  • Full HD resolution 1920 x 1080 gives crystal clear viewing
  • 5ms response time for sharp images with no ghosting
  • Specifications:
  • Width: 53.6cm, Depth: 19cm, Height: 40.3cm
  • Weight: 5.2kg
  • Diagonal Size: 22 inch widescreen
  • Dot Pitch / Pixel Pitch: 0.248mm
  • Max Resolution: 1920 x 1080
  • Video Format: 1080p (full HD)
  • Colour Support: 24-bit (16.7 million colours)
  • Max Sync Rate (vxH): 61hz x 75 khz
  • Response Time: 5ms
  • Display Positions: Tilt
  • Tilt Angle: 20
  • Output Power Channel: 3 Watt
  • Features: Wall Mountable
  • 12 Months Warranty
  • Open box
Samsung 22 Inch Wide HD 1080P LCD TV (Open Box)
Ultra-slim and ultra-elegant, the ToC design is inspired by the artistic integrity of hand blown glass. The translucent charcoal gray gradation of the bezel and cobalt blue hues of the clear crystal neck subtly shift in color depending upon external light conditions, creating an exquisite interplay between the monitor and the environment that it is placed in.
Full HD 1,080p purity
When you view images in Full HD 1,080p you aren’t merely watching, you are actually experiencing. Images are saturated with rich, realistic detail, complete natural color coverage, and fast, fluid motion, allowing you to partake in entertainment like never before.
stylist Crystal Neck
The exquisitely tapered clear Crystal neck makes the monitor screen looks float in the air. With its delicate cobalt blue hue it gently accentuates the charcoal gray ToC gradation on the bezel and embodies the principals of modern beauty and minimalist elegance.
extra energy efficient
By using energy saving technology, we have been able to reduce power consumption without loss of picture quality. Using up to 33% less energy than conventional monitor, the impact of this environment friendly technology really adds up, saving your money and the world fossil fuel on a daily basis.
faster clearer images
With a phenomenally fast response time of 2ms, blurring, ghosting, and trace effects are a thing of the past. Even the fastest action scenes are presented with a purity of picture that appears natural, seamless, and smooth.
more style more space
The ultra-slim 30mm depth not only creates more style in less space but also ensures exceptional all round efficiency. Up to 50% slimmer than traditional monitors, the modern, organic contours gently accentuate the elegance of your lifestyle and home.
dynamic color, dramatic detail
The phenomenal 50,000:1 Dynamic Contrast ratio achieves immaculate image integrity. Through intelligent automatic backlight adjustment, deeper black and brighter white tones are created, enabling every image to be presented with rich, realistic color and dramatic depth of detail.
touched by starlight
With a touch, monitor function buttons appear with a soft, mellow Starlight glow. In contrast with the pure black beauty of the organically contoured bezel, the Starlight buttons allow you to enjoy elegant interaction with the monitor and then back to invisible again.
100% VOC free
The dual injection molding technique used to create the ToC finish emits no VOCs (Volatile Organic Compounds) and uses no lead based paint, making a monitor that has zero environmental impact from the day it is made right through to the day it is recycled.
complete viewing option
Optimized for movies, games, and Windows Vista, the 16:9 format not only enhances the enjoyment factor of entertainment, but also enables a more efficient work environment to be created. 16:9 fits images into the screen so that they appear natural and comfortable to the eye.
New Open Box Product comes in original box in as new condition. Grade A Product will be in an excellent condition and show only light signs of wear and tear. Grade B Product is complete and tested, with no visible flaws. There will be signs of use including general wear and tear on the keyboard and mouse . There could be surface scratches. (This does not include the screen) Grade C Product has definite signs of use, heavy surface scratches including general wear and tear on the keyboard and mouse. The machine will be fully functioning. Grade D Product will be functioning, but show signs of heavy use. May have cracked casing or similar, worn keyboard, worn mouse, and may have minor monitor damage i.e. a pixel dot on the screen.
