Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
Caxton royale wide tv entertainment unit
Metropole Ocean TV entertainment unit
Caxton Coniston wide TV entertainment unit
The Furniture Factory Worcester TV En...
Caxton Coniston wide TV entertainment...
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
Wall mountable TV entertainment unit
 More...Prices updated November 23rd at 10:30am and include delivery.
For Sale : Alphason Aragon Stand (silver) hawkone Non Electrical Goods Classified Adverts 0 10-05-2009 6:32 AM
For Sale : Alphason Aragon Stand (silver) hawkone Home Cinema and Hi-Fi Equipment Classified Adverts 1 09-05-2009 5:15 PM
Old 17-05-2009, 9:15 AM   #1 (permalink)
Alphason AMBRI
My six month search for an AV rack is almost come to an end (I think!).
My equipment list is as follows: (TV is already wall mounted):
- Yamaha 3800 amp
- Media box (Kuro KRPA 500)
- PS3
- SKy HD
- Media server (tranquil T7)
- Squeezbox
..and Blu Ray player to come
The only product that comes close to fitting my requirments (also needs to be lockable or at least have a glass door) is the alphason ambri 1100. However, I have two questions:
1. Can I stack these units in top of each other (I will need two to fit everything)
2. Can anyone tell me if the amp ill fit inside (the amps measurements are H:171mm W: 435mm D: 439mm
If anyone can make a better suggestion, I am happy to listen!
Thanks.
drdes is offline   Reply With Quote
Old 18-05-2009, 8:31 PM   #2 (permalink)
Thanks: Gave 21, Got 17
Re: Alphason AMBRI
You can find the dimensions of the cabinet here:
Alphason ABR1/100-White - Alphason AMBRI Series - Alphason Stands - Stand and Deliver
Looks like it is not deep enough for your amp though at only 410mm
I too am looking for a stand and have found one that I think might do the job. See link below
Stand recommendations - lots of kit!
That is deep enough for your amp and might be big enough to get the rest of your kit in.
Edit: I realise it doesn't have doors however, so may not be suitable
penfold27 is offline   Reply With Quote
Old 19-05-2009, 6:57 PM   #3 (permalink)
rick1409's Avatar
Thanks: Gave 72, Got 61
Re: Alphason AMBRI
- Yamaha 3800 amp
- PS3
- SKy HD
- Squeezbox
Thanks.
Just had one of these delivered in black, Very nice cabinet.
Just had a measure up for you and there isn't enough Depth for your amp.
430mm from the very back up to the door, and obviously you need room for cables etc.
Rick
rick1409 is offline   Reply With Quote
Old 19-05-2009, 8:57 PM   #4 (permalink)
Thanks: Gave 22, Got 6
Re: Alphason AMBRI
There is loads of information on this cabinet on the "opinion needed" thread lower down this page, there is also another thread if you search for it, dont know how to post links, but the cabinet is realy good quality, you will need to cut the back out to connect all the cables, best to cut out before assembly, also opening up the back will aid with heat dissipation. I have posted before about stacking these cabinets I dont think it will work, without a spacer, as the door swings down as it pivots and would bind on the "lower" door.
One poster on the other thread has suggested the hinges sheared on his but i can not see how this would happen as there is a stay to secure the door.
Have a look on the other threads and if you still have questions i will try to help, by the way i do not make or sell these just own one.
Hope this helps.
john_b is offline   Reply With Quote
Old 23-05-2009, 7:56 PM   #5 (permalink)
Thanks: Gave 25, Got 22
Re: Alphason AMBRI
I have two of these side by side that houses all my kit. see on page 2 here:Such's Lounge project (Thanks to Groove & Homerdog )
I have cut the back out of one to house my onkyo 805, but I have access behind as there are patio doors behind the wall, you can see if you go through the thread. Overall, good cabinets!
Such is offline   Reply With Quote
alphason, ambri
