Table help
Old 13-05-2009, 5:13 PM   #1
2,197, Level: 10
Points: 2,197, Level: 10 Points: 2,197, Level: 10 Points: 2,197, Level: 10
Thanks: Gave 2, Got 0
Table help
I'm having trouble finding a tv unit for my setup.
I'm looking for one that fits the following criteria:
  • £0-£250
  • Wood, preferably light wood
  • 100-160cm long
  • height not too important
  • depth - the main sticking point - needs to be 30-40mm deep
Styles that I like are 'Lack' from Ikea (too deep) - IKEA | TV solutions | TV solutions for tube TVs up to 25'' | LACK | TV bench
Mc Cord Dehli - Mc Cord "Dehli" TV entertainment unit - Additions Direct
I want to put my tv on the top and have my consoles on the shelf/shelves below.
Any suggestions are most welcome.
Old 18-05-2009, 2:10 PM   #2
Member 363549's Avatar
1,937, Level: 10
Points: 1,937, Level: 10 Points: 1,937, Level: 10 Points: 1,937, Level: 10
Lightbulb Re: Table help
The Techlink range are 400mm in depth:
Tech Link TV Stands
There are also a lot more stands at about 412mm in in depth but this may be too deep for you.
Chris
Last edited by inzaman; 18-05-2009 at 9:02 PM. Reason: Remoced text that breaks forum rule no. 7
