Help - Need to find a 19" Rack within Oak Cabinet
Old 12-05-2009, 1:52 AM   #1
3,398, Level: 13
Points: 3,398, Level: 13 Points: 3,398, Level: 13 Points: 3,398, Level: 13
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Title says it all am having no luck searching and would appreciate some help.
Old 12-05-2009, 7:05 AM   #2
wizbongre's Avatar
4,921, Level: 16
Points: 4,921, Level: 16 Points: 4,921, Level: 16 Points: 4,921, Level: 16
Thanks: Gave 55, Got 65
Re: Help - Need to find a 19" Rack within Oak Cabinet
What about finding a suitable cabinet and then adding the rackmount supports to it? Of course, you'll need to ensure the space in the cabinet is the correct size which may be just as hard!
You could always commission a custom made job?
Good luck.
