Please Help Me Find a Stand
Old 09-05-2009, 8:08 AM   #1
1,850, Level: 9
Points: 1,850, Level: 9 Points: 1,850, Level: 9 Points: 1,850, Level: 9
Thanks: Gave 2, Got 0
I know I will not be the only one in this position, but I am finding it difficult to find a stand to house my AV kit.
My main problem is my centre speaker as it is larger than most speakers.
My requirements:
  • Black Glass Shelves
  • 2 Shelves
  • Top shelf for speaker. Speaker Size - 455mm (W) x 180mm (H) x 175mm (D)
  • Bottom Shelf for AV kit - 900mm (W) x 160mm (H) x 380mm (D)
The only one I have found that may suit my requirements is the Alphason ADP3. There is also the same stand without the TV mount.
Are there any other cheaper stands that would suit my needs?
Thanks.
Old 10-05-2009, 6:11 PM   #2
1,870, Level: 10
Points: 1,870, Level: 10 Points: 1,870, Level: 10 Points: 1,870, Level: 10
Re: Please Help Me Find a Stand
This may not be of interest, but have you thought about changing your centre speaker? Is your tv going on the stand or the wall?
The reason I ask is I had a similar situation and considered a wall mounted centre channel under the tv. Something like this, which is a very reasonable price (and cheaper than most stands) IPL AVC1 SHIELDED CENTRE SPEAKER
Or if you dont feel like putting one together then maybe something from the Kef wall mount range or PMC Wafer - although a more expensive option.
Then you could get whatever stand you wanted to house the rest of your kit with less restrictions.
Just a thought.
Ben
Old 11-05-2009, 8:55 AM   #3
Member 363549's Avatar
1,937, Level: 10
Points: 1,937, Level: 10 Points: 1,937, Level: 10 Points: 1,937, Level: 10
Lightbulb Re: Please Help Me Find a Stand
These could be big enough for your kit:
Ateca Bordeaux 120 TV Stand
Gokeda Classic TV Stand
GT 11 Black TV Stand
Hope this helps
Old 11-05-2009, 10:00 AM   #4
1,850, Level: 9
Originally Posted by Just TV Stands View Post
Hope this helps
Do you have any pictures with all the measurements in them for the Ateca and Gokeda stands e.g. distence between shelves etc, not just the outside measurements?
Thanks.
Old 11-05-2009, 1:26 PM   #5
1,937, Level: 10
Here is the spec for the Ateca Bordeaux:
http://www.bbg.eu.com/cms_files/64/Ateca_Bordeaux_BOR126_AV_Furniture.pdf
The distance between each shelf is just over 20cm.
We currently have nothing else for the Gokeda stands as we only started to sell them a few days ago. We will try and get more info on the site ASAP.
Kind Regards,
Chris
Old 12-05-2009, 10:51 AM   #6
2,142, Level: 10
Points: 2,142, Level: 10 Points: 2,142, Level: 10 Points: 2,142, Level: 10
Thanks: Gave 75, Got 72
Whereabouts are you?
Old 12-05-2009, 10:53 AM   #7
1,937, Level: 10
We are based in Yeadon near Leeds.
Old 12-05-2009, 10:58 AM   #8
2,142, Level: 10
sorry that was for cbrmick777
