Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
John Lewis Maharani Corner TV Unit
John Lewis Stowe TV Unit
John Lewis Matilda Bar Chair, Black
The Furniture Factory Worcester TV En...
Ellis Entertainment Unit, Light
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
 More...Prices updated November 22nd at 9:30pm and include delivery.
Heating system advice - open system Newton's Ring General Chat 9 27-04-2009 6:12 PM
Recommendation for a cheap source of heating Ivor the Engine Reducing Your Carbon Footprint 13 21-04-2009 9:13 PM
Old 05-05-2009, 12:59 PM   #1 (permalink)
Thanks: Gave 34, Got 41
Help with old la-z-boy recliner with heat & massage
I picked up a pair of old la-z-boy recliners with heat and massage built in. One worked and the other one didn't. I tried the power supply off the one that didn't work on the chair that worked. It didn't work proving that the power supply was faulty.
I then tried the power supply from the working chair on the non working one and after a few seconds there was a burning smell and the control pad became very hot. This has in turn knackered the working power supply.
I bought a new power supply that matched the specs of the original to at least get the functional chair up and running but it just flashes 'dc' on the controller pad. The new one is centre terminal positive but I don't know what the original was.
Anybody got any ideas?
Cheers,
EDIT I have just realised why 'dc' is flashing. The output needs to be AC. I think I will take a look at the control pad and other electrics on the faulty chair and if I can suss out what must be causing a short I will look for pair of adapaptors to save on postage. If I can't fix it I will just order one.
Graham
Graham N is offline   Reply With Quote
heat, lazboy, massage, recliner
