Cantilever stand to fit Pioneer 60" - with 850mm centres?
Old 24-04-2009, 6:14 PM   #1
dealmaker's Avatar
8,315, Level: 21
Points: 8,315, Level: 21 Points: 8,315, Level: 21 Points: 8,315, Level: 21
Thanks: Gave 28, Got 0
My Pioneer LX608 has 850mm centres for the rear bolts.
Does anyone know of a Cantilever (single pillar style) stand that will accomodate the Pioneer 60"??
Most of the stands I have seen only got to 50 or 55" - and tend to max out at 800/830mm width for the bolts.
Thanks!!!
Old 27-04-2009, 3:47 PM   #2
Assured Advertiser
m-formonline's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 20, Got 299
Re: Cantilever stand to fit Pioneer 60" - with 850mm centres?
Both these cantilever stands will fit as we can provide adapters FOC with the stand;
M-Form - "CUBO 2" AV Table for 32" to 52" TVs *10
M-Form - "CUBO" AV Table for 32" to 52" TVs *10%
Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
