Custom Design Milan Plasma 3 Problem
Old 24-04-2009, 1:24 PM   #1
skk3's Avatar
6,467, Level: 19
Points: 6,467, Level: 19 Points: 6,467, Level: 19 Points: 6,467, Level: 19
Activity: 16.7%
Activity: 16.7% Activity: 16.7% Activity: 16.7%
Thanks: Gave 68, Got 100
I have just purchased this stand and noticed that my 40inch LCD makes the top shelf bow slightly! The shelves are built to take up to 30kg; my TV is only 20.5kg. Is the glass faulty. I would appreciate any help with this issue. Cheers.
Old 26-04-2009, 7:05 AM   #2
skk3's Avatar
6,467, Level: 19
Activity: 16.7%
Re: Custom Design Milan Plasma 3 Problem
Update - Custom Design have shown excellent customer service and will be providing me with a slightly thicker upper shelf to cure the problem. Cheers.
Old 26-04-2009, 10:19 PM   #3
2,171, Level: 10
Points: 2,171, Level: 10 Points: 2,171, Level: 10 Points: 2,171, Level: 10
Thanks: Gave 0, Got 2
Out of interest where/who did you purchase this off? And did the retailer not help solve the problem?
Old 27-04-2009, 8:34 AM   #4
skk3's Avatar
6,467, Level: 19
Activity: 16.7%
Hi Wired-man, the stand was purchased from Peter Tyson, but due to the nature of the fault, I wasn't too sure that they would be able to help. Further emails from Custom Designs mentioned that although they would issue a replacement shelf and wooden side blocks, I would have to return the first glass shelf at my expense. The glass shelf is very heavy, so I don't know what that will cost................
