will this stand fit my sony kdl40w4000 ?
Old 21-04-2009, 7:13 PM   #1
1,321, Level: 8
Points: 1,321, Level: 8 Points: 1,321, Level: 8 Points: 1,321, Level: 8
Just wondering if this stand would fit my sony kdl 40w4000 TV?
Stil-Stand Cantilever STUK-2053CHBL - Stil-Stand - Stand and Deliver
i dont know much about the fittings on these newer LCDS.
cheers
Old 22-04-2009, 6:39 AM   #2
Assured Advertiser
m-formonline's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 20, Got 299
Re: will this stand fit my sony kdl40w4000 ?
Yes it will fit by the looks of it. The VESA mountings on the TV are 300mm x 300mm and the bracket on the stand looks like it'll easily fit that.
Hope this helps.
Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
Old 22-04-2009, 12:22 PM   #3
2,162, Level: 10
Points: 2,162, Level: 10 Points: 2,162, Level: 10 Points: 2,162, Level: 10
Thanks: Gave 1, Got 2
Hi the bracket dimensions for this stand are 800mm width by 445mmheight so if the mounting holes on your tv are 300 x 300 theres no reason why your tv wont fit this stand.
