Speaker wall mounts
Old 18-04-2009, 5:09 AM   #1
1,332, Level: 8
Points: 1,332, Level: 8 Points: 1,332, Level: 8 Points: 1,332, Level: 8
Thanks: Gave 7, Got 5
Speaker wall mounts
Hi All,
Can you please express your 'feelings' about wall mounts for rear speakers.
There are some pictures attached.
I'd like to use them with B&W 686.
Many Thanks
Speaker wall mounts-551448613.jpeg   Speaker wall mounts-551448613_1.jpeg   Speaker wall mounts-551448613_2.jpeg   Speaker wall mounts-551448613_3.jpeg   Speaker wall mounts-551448613_4.jpeg
Old 18-04-2009, 11:21 AM   #2
2,051, Level: 10
Points: 2,051, Level: 10 Points: 2,051, Level: 10 Points: 2,051, Level: 10
Thanks: Gave 10, Got 5
Re: Speaker wall mounts
Where are they from they look very smooth
Old 18-04-2009, 8:28 PM   #3
1,332, Level: 8
They are hand made on order by craftsman of stainless steel and finished in INOX satin.
Old 18-04-2009, 9:02 PM   #4
swift1's Avatar
3,839, Level: 14
Points: 3,839, Level: 14 Points: 3,839, Level: 14 Points: 3,839, Level: 14
Thanks: Gave 62, Got 67
If it can support the Kefs than the 686 will be fine but not sure how secure it will be - is there a way of securing the speaker on the monunt? BTW they do look fab, must have cost you a bomb!
Old 18-04-2009, 10:24 PM   #5
1,332, Level: 8
I was also wondering how to secure speakers on those brackets. There are no holes or other visible mount points. The only way to do that would be some kind of glue/silicone which would be strong enough to keep them in place but also easily removable if you want to remove them.
The guy who design them willing to do set for me and asking £ 60 for pair.
What do you think?
