Advice: LCD Wall bracket with built in shelf / rack
Old 20-01-2009, 10:19 PM   #1
Waq Waq is offline
2,090, Level: 10
Points: 2,090, Level: 10 Points: 2,090, Level: 10 Points: 2,090, Level: 10
Hi everybody.
I am looking for a LCD wall bracket for a 32" Samsung LCD TV. I would prefer a versatile bracket which will handle a larger TV if I decide to purchase a 42" TV in the future.
What I would like the wall bracket to have is a built in shelf / rack, which is able to hold the a SKY HD box and DVD player.
Any suggestions on such a product or where to look? I have tried google and search on this forum but maybe searching with the wrong words!
I presume that such a wall bracket will be able to hide any HDMI cable etc which will leave the power cable only to hide.
My power socket is quite far from where I wish to position the tv and not keen on moving it due to the decoration and cost implications. Do you suggest trunking straight from the TV to skirting and then continue the trunking at a right angle to the power socket, or does anybody know of a more effective method / product?
Many thanks in advance!
Old 21-01-2009, 7:58 AM   #2
Assured Advertiser
m-formonline's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 20, Got 299
Re: Advice: LCD Wall bracket with built in shelf / rack
This would be perfect for your needs;
M-Form - 32" to 50" Corner Bracket With 2 Shelves
This is a 32" to 50" corner bracket which can be use either in a corner or on a flat wall with the shelves. There are two shelves for kit and the whole thing swivels once mounted so your kit swivels with your TV. Here are some more images and installation suggestions;
M-Form
Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
Old 03-02-2009, 9:43 PM   #3
Waq Waq is offline
2,090, Level: 10
Thanks, I have ordered the m-form bracket.
I missed the courier today. I will hopefully receive it tomorrow!
