Help! Stand for Wharfedale CS needed!
Old 20-01-2009, 10:39 AM   #1
2,421, Level: 11
Points: 2,421, Level: 11 Points: 2,421, Level: 11 Points: 2,421, Level: 11
Thanks: Gave 77, Got 27
I have ordered a Wharfedale CS (center speaker) but I just realised it is about 20cm high! So I need to get a TV stand which will let me put it on the shelf beneath the TV, which is a 40 inch Sony W4500. I also need something with space for a Sony 2400ES amplifier which is about 16cm high (so on the shelf below the speaker). So I basically need a (preferably black glass) stand with 2 shelves of around 20cm each. But added to that, I need space for a Sony BDPS350 and my Xbox360!
Anyone have any ideas for me?
Old 20-01-2009, 3:31 PM   #2
Assured Advertiser
m-formonline's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 20, Got 299
Re: Help! Stand for Wharfedale CS needed!
We have our 'CUBO' here;
M-Form - "CUBO" AV Table for 32" to 50" TVs
This will allow you to put your centre speaker on the top shelf directly under the TV which will be mounted on the column. The rest of your equipment will fit on the other two shelves which have 170mm clearance each (190mm actual clearance between glass)
Give me a shout of you need any more info.
Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
RationalGaze (21-01-2009)
