Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
John Lewis Maharani Corner TV Unit
John Lewis Stowe TV Unit
John Lewis Matilda Bar Chair, Black
The Furniture Factory Worcester TV En...
Ellis Entertainment Unit, Light
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
 More...Prices updated November 22nd at 8:30am and include delivery.
For Sale : Windows MCE Remote + USB Receiver Lighty Computer Classified Adverts 7 19-01-2009 10:02 PM
Old 18-01-2009, 8:38 PM   #1 (permalink)
Thanks: Gave 8, Got 0
Best rack for Onkyo receiver??
Hi folks, advice needed for a rack/stand for my Onkyo amp. Will be wall mounting tv soon and will need a rack for amp, dvd player, cable box, xbox 360, and wii. Have read posts and see that most racks not suitable for Onkyo because there a beast of a size. Any recommendations guys or even any kit that will be soon be surplus to your requirements and available for sale?
n18lld is offline   Reply With Quote
Old 22-01-2009, 9:18 AM   #2 (permalink)
pooper's Avatar
Thanks: Gave 48, Got 12
Re: Best rack for Onkyo receiver??
I don't think you really need anything specifically 'special'
I decided to go on an Optimum rack, mostly due to the fact I could pick each shelf height to fit my exact requirements.
They have 2 'depths' 400mm and 500mm, you'll pretty much have to go with the 500mm one (i.e. not the Slimline range).
Hope that helps!
(i'll be posting pics of mine when I FINALLY receive it.........) :D
Setup: Pioneer Kuro KRP-600M// Onkyo TX-NR906 // Monitor Audio GS Series (Fronts: GS60 Centre: GSLCR Rears & Sides: GSFX Sub: SVS PC-Ultra) // 360 Elite // Panasonic DMP-BD80 // SkyHD // What credit crunch?
pooper is offline   Reply With Quote
n18lld (22-01-2009)
Old 22-01-2009, 10:30 PM   #3 (permalink)
Hope that helps!
Thanks pooper, currently looking at Optimum 5500 with the wood legs. Best price appears to be £273. Probably order in a week or so.
Old 25-01-2009, 11:14 PM   #4 (permalink)
Thanks: Gave 5, Got 34
My Onkyo 905 really needed a 545mm deep rack to allow sufficient room for the cables at the back!
Cyril is offline   Reply With Quote
n18lld (26-01-2009)
Old 30-01-2009, 4:01 PM   #5 (permalink)
I@n
I've just purchased a Blok 400 for my setup. My onkyo 876 fits perfect in the bottom shelf with a little bit of room on the top for air flow. Its only got a depth of 400mm however so does over hang a little at the back with the cables but it still looks good!
I@n
I@n is offline   Reply With Quote
Old 30-01-2009, 11:45 PM   #6 (permalink)
pooper's Avatar
I received my Optimum rack today......... all 70KG of it!!
I thought they made a mistake when they told me on the phone, or i'd just misheard '17KG' ... but no!
I'll get some pics up soon :D
Old 31-01-2009, 9:47 AM   #7 (permalink)
inzaman's Avatar
Thanks: Gave 91, Got 365
70KG That thing weighs more than me
Visit my Home Cinema here
inzaman is offline   Reply With Quote
Old 31-01-2009, 10:11 AM   #8 (permalink)
wiz
Thanks: Gave 31, Got 21
Another vote for the Optimum AV400, great rack
Panasonic TH-37PX7B, Onkyo 875 ,
Sony BDP-S350, Sky+
Front Mission 773, Center Canton CD50, Rear Mission 70DS
wiz is offline   Reply With Quote
Old 31-01-2009, 11:41 PM   #9 (permalink)
thenicklouse's Avatar
Thanks: Gave 11, Got 32
I have been running my 805 on some sound style 120's for some time with no probs.
gives me about 2 inch to the shelf above and open all around.
Runs no hotter than the stereo amps.
HiFi: Amps C372,C272. CD C542. Soundbridge, Squeezebox, Dac Magic, phono pre amp NAD PP2. Pro-ject 2 Xperience, B&W 703's
AV: DVD T585. HD-XE1. DMP BD35. TX-SR805. PDP-5080XD. Infinity Beta HCS 7.1. and a Wii.
thenicklouse is offline   Reply With Quote
Old 01-02-2009, 3:17 PM   #10 (permalink)
pooper's Avatar
I've posted some pics of my Optimum rack (with an Onkyo 906, for size comparison):
My new Optimum AV400
Old 01-02-2009, 9:54 PM   #11 (permalink)
that does look like it is going to be a bit tight for ventilation.
Old 02-02-2009, 7:44 AM   #12 (permalink)
pooper's Avatar
Should be okay, there's about a 5cm gap between the receiver and the shelf.
Old 21-02-2009, 11:53 AM   #13 (permalink)
ian
I am considering buying a blok400 for the same amp.
Have there been any overheating or operational problems with the amp on the bottom shelf, given the limited amount of space.
Regards
Tony
tony1 is offline   Reply With Quote
Old 21-02-2009, 12:10 PM   #14 (permalink)
I@n
The Blok 400 bottom shelf is fine for the 876. Not too sure if it would fit on the middle shelf. It has half an inch gap either side of the amp and has a good 2 inch gap on the top. The amp does hang out of the back slightly (which is good for air flow) so you'll have a a 1 inch gap away from the wall but I have it under my TV so don't really walk over to that wall.
No problems at all with over heating. This is a very good amp and haven't had any problems (touch wood).
I would certainly look around at prices. I've seen this from £240 to £400. I got a display one for £240 from my local furniture store in cherry with sandstone glass.
Old 24-02-2009, 12:55 PM   #15 (permalink)
Thanks: Gave 23, Got 21
Hi all,
I have just been doing a little research and it seems that you can customise the optimum AV400 range to meet your own needs at no extra cost:
Optimum 2000 International - Optimum International, Optimum Modular, hi-fi, audio, TV stand, sound, cinema, satellite
So the bottom rods can be 250mm/320mm rather than the 230mm standard giving you that little extra space for ventilation..
Suddenly shot to the top of my list!
Edit - Just read Poopers post above and see he has mentioned it already.. Must have skimmed over it!
Panasonic TX32Lxd500 / Onkyo 876 + MA RS6 fronts MA BRLCR centre & B&W 601s2 rears / Panasonic DvD Recorder / Sky+ / PSP / DSLite / PS3 *PSN - NBUK *
..::BFaM::..
NBUK is offline   Reply With Quote
onkyo, rack, receiver
