Hold The Music
Old 16-01-2009, 9:09 AM   #1
3,460, Level: 13
Points: 3,460, Level: 13 Points: 3,460, Level: 13 Points: 3,460, Level: 13
Thanks: Gave 125, Got 36
Hold The Music
Had a couple of units made to house my gear. It's done to your own design and spec - but don't worry if you've no talent 'cause Mark will help with that. Just supply details of kit sizes etc and an idea of style and he'll put some drawings together for you.
Pictures on this thread, post 15.http://www.avforums.com/forums/arcam...-set-up-2.html
Old 17-01-2009, 9:13 AM   #2
Knightshade's Avatar
11,666, Level: 25
Points: 11,666, Level: 25 Points: 11,666, Level: 25 Points: 11,666, Level: 25
Thanks: Gave 13, Got 51
Re: Hold The Music
They look very nice, if memory serves the new Onkyo range should fit!
Old 19-01-2009, 10:01 AM   #3
3,460, Level: 13
Re: Hold The Music
I see you are another Hold the Music satisfied customer. As for a new receiver, I'm a bit of an Arcamite so I'm looking at the AVR600. Need to loose both the Pio and Samsung you can see at the bottom of the rack, but the Sony 350 will take care of DVD needs (as soon as I get it switched to region free - waiting to get hold of the appropriate remote).
