AV Rack/Cantilever for Plasma Screen, Amp & HTPC
Old 12-01-2009, 10:48 PM   #1
Oli Oli is offline
7,399, Level: 20
Points: 7,399, Level: 20 Points: 7,399, Level: 20 Points: 7,399, Level: 20
Thanks: Gave 1, Got 2
Hi all,
I need some help finding the right solution to my AV system. I want to upgrade my current speaker setup but i'm currently restricted as I can only fit a small centre speaker on my current rack. I'm looking for a solution that will be able to hold a reasonably large centre speaker under the Panasonic TH42-PHD8 screen along with the Onkyo and HTPC. Ideally i would like to be able to store my Xbox and Sky box there as well but i think that might be difficult.
I was looking at something like this:
Universal LCD/Plasma up to 42 inch ZIN421459/BKI TV Stand ZIN421459/BKI
Atacama Cantilever 2 Shelf TV Stand - Black Equinox AVI TL - BK
Both only 2 shelves
Alphason | AD Series - Model: ADP3/96-PB
I don't think this one will fit the centre speaker underneath the panel
Alphason | Iconn Series - Model: ST210 140-B
I think i could potentially fit a centre speaker AND things either side of that one
Does anyone have any recommendations or other ideas i might want to consider?
Old 20-02-2009, 12:04 AM   #2
jameson_uk's Avatar
15,261, Level: 29
Points: 15,261, Level: 29 Points: 15,261, Level: 29 Points: 15,261, Level: 29
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 87, Got 550
Re: AV Rack/Cantilever for Plasma Screen, Amp & HTPC
Came up with roughly the same shortlist as you. The Onkyo is the pain as most racks wont take the weight or depth of the thing.
Just wondering if you got one of these and if so how you got on?
Old 21-02-2009, 12:36 PM   #3
2,011, Level: 10
Points: 2,011, Level: 10 Points: 2,011, Level: 10 Points: 2,011, Level: 10
What about this bud? I know its a 3 shelfer but would fit everything in.
90cm Black Leg Cantilever Stand
or this?
http://www.allcam.biz/catalog/produc...roducts_id=584
