Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
Caxton royale wide tv entertainment unit
Metropole Ocean TV entertainment unit
Caxton Coniston wide TV entertainment unit
The Furniture Factory Worcester TV En...
Caxton Coniston wide TV entertainment...
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
Wall mountable TV entertainment unit
 More...Prices updated November 23rd at 5:30pm and include delivery.
Should I Buy Samsung LE32A457C1 32" LCD TV TAZMANUK Which LCD TV Should I Buy? 6 17-06-2009 5:26 PM
Monitor vs Lcd screen question. bodski100 Computer Monitors 7 05-06-2009 7:25 PM
For Sale : PANASONIC TX26LXD1 LCD TELEVISION WITH FREEVIEW gazza166 TV and Projector Classified Adverts 14 19-01-2009 12:05 PM
Buying an LCD TV with photo sensitive epileps Graham_UK Which LCD TV Should I Buy? 2 12-01-2009 1:23 AM
Old 11-01-2009, 4:22 PM   #1 (permalink)
Thanks: Gave 3, Got 0
Alcove wall mounting LCD advise
Hi, i am unfortunate enough not to have a flat wall (perfect cinema setup option). My tv (Sony 40w4500) would need to be place in an alcove. The alcove width is 1050mm wide.
I would like to wall mount the tv, but the bracket would need to pull out by about 30 - 50 cm, turn and tilt. The problem i then have is although the tv would be at its best position where do you put the centre speaker? Does anyone know'have pictures of a similar situation?
If i go for a cab it would have to be something like the alphason ambi 800 style. However, i think this is a little low.
My equipment is 40w4500 (around 97cm wide), Denon 3805, Sky HD and PS3.
Any advice would be appreciate even if it is just a link.
Ta
crocandy is offline   Reply With Quote
Old 11-01-2009, 4:38 PM   #2 (permalink)
Thanks: Gave 11, Got 330
Re: Alcove wall mounting LCD advise
I had a similar dilemma as the previous owners built a 5" deep aclove into the brick fireplace...just the right size for the 40" LCD they had...and I wanted to put my 58" Panny plasma on top ...so needed a mount that would allow me to have the screen 5" out as it were.
the only one I found at the time (18 months ago) that was good enough for 70Kg etc was a rather expensive (£300) Ultimount UCL-X...I am very pleased with it though - the package, quality, instructions, perceived strength of the mount was far better than the other 2 mounts Ive got elsewhere in the house on 37/32" screens...so yeah, a top mount, just costs top money
cant help with the centre speaker, as mine is a wall mount Gallo Ref Centre, so its mount is just screwed directly into the fireplace underneath
cheers, bogie
t72bogie is offline   Reply With Quote
advise, alcove, lcd, mounting, wall
