the best glass cabinet/shelves and tilt swivel mount with shelf for LG 32 inch...
Old 29-12-2008, 6:47 PM   #1
Thanks: Gave 20, Got 15
So I go ahead and buy an 32LG7000 from currys the other day because I couldnt resist the price. I was planning to get one for ages but didnt plan anything.. so this was as spontaneous as it gets. This is for my bedroom. What I now need is a tilt and swivel mount to go and some sort of floating glass shelf for my sky HD box. Can anyone recommend a good cheap mount and some glass shelf setup for me?
Side note: I plan to drill behind the TV for the sky cables and phone wire, just thinking how to give it power. Need 2 power sockets in there somehow. Any help would be much appreciated.
Ok.. thats one of the issues. I also was to make my living room as clean as possible as well. I want to have the same floating glass wall shelf thing for my gear. Some recommendations for that would also be appreciated.
This is what I found so far:
HIFI STAND BLACK
Much appreciated.
Old 29-12-2008, 6:49 PM   #2
Re: the best glass cabinet/shelves and tilt swivel mount with shelf for LG 32 inch...
Oh yes, with both shelves, ideally I would like to conceal the wires of my equipment..
Old 30-12-2008, 12:50 AM   #3
I found this for the bedroom solution... any thoughts?
vogels TVA2406
Anyone?
