First post - glass stand req. for 42pz80
Old 16-09-2008, 11:45 AM   #1
2,175, Level: 10
Points: 2,175, Level: 10 Points: 2,175, Level: 10 Points: 2,175, Level: 10
Thanks: Gave 1, Got 0
Firstly I should say hello - this is my first post on the avforums site.
Secondly I'm in need of a decent stand for my shiny new tv - I managed to strech the budget and go for a Panasonic TH-42PZ80 which (thanks to a friend of the family who works for argos) I managed to get for £688.50.
I did take argos up on their half price stand offer and ended up with this
http://www.argos.co.uk/static/Produc...er/5270048.htm
generic multifunction tv stand.
The main problem I have with it is that the middle shelf rests on three tiny L shaped screw in pieces of metal around 15mm wide, it's no where near stable enough. Given that argos are charging £129.99 for this stand normally, I wonder who in their right mind would pay that for it?
Anyway, the stand is going to go in the corner of a modern apartment room - wooden floors and white walls, and it needs to be glass. I'd prefer it in black glass but as I've just bought a clear glass desk to sit nearby, my girlfriend wants it to be clear.
The budget isn't fantastic I'm afraid - upto £70, so I'm hoping someone might be able to recommend a decent clear glass (black considered) corner unit to fit a 42" plasma. If it has space for two satellite speakers (using a Logitech Z-5500 sound setup) then I'd be very pleased indeed.
All help appreciated!
Old 16-09-2008, 11:49 AM   #2
Lucas44's Avatar
1,841, Level: 9
Points: 1,841, Level: 9 Points: 1,841, Level: 9 Points: 1,841, Level: 9
Thanks: Gave 12, Got 29
Re: First post - glass stand req. for 42pz80
check out this site:
http://www.standanddeliver.com/acata...ds_Corner.html
never used them personally but they seem pretty decent and their sale is on! HTH
LessThanFlake (16-09-2008)
