Looking for black satellite speaker stand
Old 13-09-2008, 2:22 PM   #1
1,383, Level: 8
Points: 1,383, Level: 8 Points: 1,383, Level: 8 Points: 1,383, Level: 8
Does anyone know of anywhere for some nice black speaker stands?
Strange as black seems to be the av 'in' colour, but nearly all the stands I've found are silver
Not too expensive either (hopefully)
Old 14-09-2008, 4:53 PM   #2
Assured Advertiser
8,384, Level: 21
Points: 8,384, Level: 21 Points: 8,384, Level: 21 Points: 8,384, Level: 21
Activity: 4.5%
Activity: 4.5% Activity: 4.5% Activity: 4.5%
Thanks: Gave 28, Got 237
Re: Looking for black satellite speaker stand
Is this what you are looking for? They come in black as well as silver.
http://www.quantumelectronics.co.uk/...ker_stand.html
Soundstyle Z2 Speaker stand
Old 14-09-2008, 5:05 PM   #3
1,383, Level: 8
Thanks quantum but am looking for satellite speaker stands, as put in heading
Old 14-09-2008, 7:05 PM   #4
Assured Advertiser
8,384, Level: 21
Activity: 4.5%
Ah, let me know which speakers you have and I will see what I can find. We do have the black KEF stands but we may be able to find some others.
Old 14-09-2008, 9:09 PM   #5
1,383, Level: 8
Hi Quantum
Awaiting delivery of Onkyo HT-S5105 package. Have Kef speakers and stands in living room, that was easier as silver set up.
[FONT=Arial, Helvetica, sans-serif][/FONT]
Old 15-09-2008, 8:58 AM   #6
6,583, Level: 19
Points: 6,583, Level: 19 Points: 6,583, Level: 19 Points: 6,583, Level: 19
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 98, Got 107
These ones on your site?
I'm looking for similar but I'm really after something a bit taller. My current cheap Alphason ones "lean" under the weight of my rear surrounds when fully extended!
Old 16-06-2009, 12:13 PM   #7
1,640, Level: 9
Points: 1,640, Level: 9 Points: 1,640, Level: 9 Points: 1,640, Level: 9
these threads are a bit old now...but anyone looking for a well made nice and simple design THAT WORKS WELL try the ELO omni stand - nice black tempered glass feet, black pole...a kit that will fit any satallite - got mine for £35.00 from Richer Sounds...look the business too!
had a look at them Argos jobbies...they look and feel cheap n badly designed...spend the little xtra, i.e £15 in this case and get some better quality ones that look pleasing too.
Old 16-06-2009, 1:58 PM   #8
Ads03's Avatar
4,054, Level: 15
Points: 4,054, Level: 15 Points: 4,054, Level: 15 Points: 4,054, Level: 15
Thanks: Gave 114, Got 130
I got those too, look good
Old 16-06-2009, 5:48 PM   #9
6,583, Level: 19
Activity: 2.3%
Well, believe it or not I still have the same crappy stands!
Indeed, those stands are nice but they're still far too short for me. My current ones, as wobbly as they are, go right up to 125cm.
Once I get a bigger place and don't have my surrounds peaking over furniture these would be ideal, but hopefully I'll then be in the situation where I can just get proper rear speakers
