Alphason APX50/4-B and Panasonic Plasma 50
Old 10-09-2008, 3:07 PM   #1
2,289, Level: 11
Points: 2,289, Level: 11 Points: 2,289, Level: 11 Points: 2,289, Level: 11
I am considering either the Panasonic TH50PZ80B or the Panasonic TH50PZ81B. I also need a TV stand. Will the Alphason APX50/4-B fit the above TV's? I am particularly interested in:
  • Whether the back panel of the stand will interfere with any of the connections and the wires + cables.
  • Also will the fittings on the back panel of the Alphason fit into the Panasonic TVs noted above?
In terms of size of screen and the weight, I know that the stand will fit and take the weight.
Has anyone fitted any of the above together?
I spoke to Alphason, who weren’t of much help.
Many thanks for your help.
Old 12-09-2008, 2:38 PM   #2
1,263, Level: 8
Points: 1,263, Level: 8 Points: 1,263, Level: 8 Points: 1,263, Level: 8
Re: Alphason APX50/4-B and Panasonic Plasma 50
I'am considering a Pioneer PDP-LX5090 will the Alphason stand fit this TV.
Thanks for any help
Last edited by frankietricolor; 12-09-2008 at 2:42 PM. Reason: Thanks for any help
