Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
John Lewis Maharani Corner TV Unit
John Lewis Stowe TV Unit
John Lewis Matilda Bar Chair, Black
The Furniture Factory Worcester TV En...
Ellis Entertainment Unit, Light
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
 More...Prices updated November 21st at 11:30pm and include delivery.
Sony KDF50E2010TNS 50" rear projection TV GLASS STAND question Biscuit2k Rear Projection Televisions 3 29-10-2008 12:33 AM
On offer: Nice glass big glass stand in freemans AJUK AV Stands, Cabinets, Seating and Furniture 3 22-07-2007 3:55 PM
Glass Shelf Supports TommyT AV Stands, Cabinets, Seating and Furniture 2 29-10-2005 9:28 AM
Lost Glass Shelf Supports koho1960 CRT Televisions 1 01-10-2005 3:51 PM
Old 10-09-2008, 12:48 PM   #1 (permalink)
Thanks: Gave 15, Got 12
Question about glass TV stand supports
Just bought myself a new glass tv stand, one problem is my HTPC won't fit on the bottom shelf due to the cable tidy/middle support.
My old stand was smaller and had a removable cable tidy so it fit just fine.
Stand in question is Serano SB1050 (from currys) with a maximum weight of 120kg and width is 105cm
I worked out that I can still have a support between the middle and top shelf no problem and remove the bottom one.
Equipment Top shelf:
Samsung LE40M87
ipod dock
Middle shelf:
Xbox 360
Centre speaker (about 1kg max)
Technics hifi (again not that heavy)
Bottom shelf:
HTPC (around 10kg at a guess)
Question is how safe will it be?
x1nick is offline   Reply With Quote
Old 10-09-2008, 1:18 PM   #2 (permalink)
Badger0-0's Avatar
Thanks: Gave 178, Got 1,228
Re: Question about glass TV stand supports
No problem whatsoever mate.
Your telly is only 21Kg.
My telly is 50Kg and then I've got similar kit to you too.
And I've stood on it at the same time
Probably not recommended really
That's well within limits
ASTON VILLA
Never bite the hand that feeds you. It's usually your own.
Badger0-0 is offline   Reply With Quote
x1nick (10-09-2008)
Old 10-09-2008, 1:20 PM   #3 (permalink)
Really didnt want the htpc hanging off by 2"
Old 17-11-2008, 4:40 PM   #4 (permalink)
X1 nick,
can you tell me whether this worked or not.
I want to squeeze an antec fusion onto an serano sb800.( havent bought either yet)
many thanks -
sparky
sparky.2002 is offline   Reply With Quote
Old 17-11-2008, 10:51 PM   #5 (permalink)
I have tested it without any of the supports in the middle and it worked fine.
Didn't try anything but my 40" lcd on it but it seemed fine.
In the end I just put the support between the top and middle shelf and left the bottom one without the support and its been fine for months.
Hope it helps!
Old 18-11-2008, 11:53 AM   #6 (permalink)
Thanks: Gave 18, Got 19
I am still looking for a cheapish glass/metal stand (typically Argos or M&S) to set off my TV and ancilliaries but nearly all of them are too tall, i.e about 20" in height.
Does anyone know what the general construction of these stands is and whether the vertical components and cosmetic cylindrical covers can be tailored to one's needs?
Are there, for instance, threaded members inside each leg which can be reduced by sawing etc.
Obviously a bit of work would need to be done, provided this was possible.
However I wouldn't want to ruin something costing £100 or thereabouts.
HHGTTG is offline   Reply With Quote
Old 18-11-2008, 1:09 PM   #7 (permalink)
On my last 2 stands the large metal poles inbetween the glass are around 5-7cm diameter which I guess could be cut down quite easily depending on how good your metal working skills are.
The main problem would be the rods inside which hold everything together. As there usually one long rod which just has threaded ends about 2" at each end.
Guess you could get the threaded rod from somewhere like b&q, it looks to be around m5 or m6 sizes.
My main concern would be getting the large metal poles to have a good finish
Old 18-11-2008, 2:08 PM   #8 (permalink)
Thanks. I had perhaps, naively assumed that they might be threaded over their entire length (which would be stupid, expensive and unnecessary, I suppose).
I'd really like a stand to be no higher than, say, 18" (45cms) and would need to remove about 4", typically, from those I have seen.
My LCD telly and two DVD recorders are currently standing on a black MDF stand, which was an integral part of my old CRT Sony Trinitron TV.
This does not look quite the part, even though it can be moved out of the corner, easily, for hoovering etc. (which would be a difficult procedure with some of the heavy glass stands out there).
Old 22-11-2008, 3:31 PM   #9 (permalink)
Does anyone know of any glass stands that are adjustable for overall height such that I could achieve a stand with a maximum height (from the floor) of, say, about 16/18"?
glass, question, stand, stand support, supports
