Why are some stands limited to 32" screens?
Old 08-09-2008, 7:53 PM   #1
4,680, Level: 16
Points: 4,680, Level: 16 Points: 4,680, Level: 16 Points: 4,680, Level: 16
Thanks: Gave 3, Got 18
I'm getting rather irritated in that I have found a stand that will fit my requirements exactly http://www.standland.co.uk/ZINUKGL409CL.htm but my screen will be a 37" and this stand is limited to 32".
The TV I'm after is 18KG and only 910mm wide - so its lighter than some 32" sets and only fractionally wider.
Is there any good reason why couldn't I use this stand?
Old 09-09-2008, 4:22 PM   #2
4,680, Level: 16
Re: Why are some stands limited to 32" screens?
Obviously a difficult question as no one can reply
Cmon guys, help a poor soul out.
Old 16-09-2008, 8:59 AM   #3
1,719, Level: 9
Points: 1,719, Level: 9 Points: 1,719, Level: 9 Points: 1,719, Level: 9
Thanks: Gave 1, Got 8
[FONT=Verdana]Ok, here's my view on this. Stand manufacturers/resellers must 'play it safe' when quoting the limitations of stands etc. Most firms (like the one you list) will give a max size/weight capacity of a stand and say it will be good for LCD & Plasma screens.[/FONT]
[FONT=Verdana][/FONT]
[FONT=Verdana]However, Plasma screens are heavier than LCD, therefore I think the limitations quoted will be based upon a worst case scenario - ie: the customer using a heavy Plasma.[/FONT]
[FONT=Verdana]If your using an LCD which weighs much less that the max capacity of the stand - there's a good chance you'll be ok, provided you don’t go too far beyond the max screen size quoted – remember good old physics will play a role.[/FONT]
[FONT=Verdana]I think stand manufacturers/resellers would do better if they were to list the stand/bracket limitations based upon LCD & Plasma screens separately.[/FONT]
[FONT=Verdana]If you decide not to take the risk, why don’t you look at the next model up – UKGL-410 which takes screens up to 42” and has 3 shelves.[/FONT]
