| The UK's biggest and best home entertainment electronics forums | |||||||||||||
| 4 million visitors each month | |||||||||||||
Similar Threads | ||||
| thread | Thread Starter | Forum | Replies | Last Post |
| Advice needed - fixing speaker brackets without screws | dmcmorrine | Home Cinema DIY | 2 | 09-08-2008 10:12 PM |
| Screws For Panasonic 37px70 Stand | rushdenx1 | Flat Screen TV Brackets and Mounts | 1 | 13-09-2007 12:38 PM |
| Panasonic TX-32LXD60A fixing screws | timmy0108 | Flat Screen TV Brackets and Mounts | 0 | 06-12-2006 7:00 PM |
| What screws/fixing for plasma wall mount into chip board | Gotrek | Home Cinema DIY | 3 | 20-09-2006 9:18 AM |
| Panasonic PW7 Stand Screws ? | rickyroma | Flat Screen TV Brackets and Mounts | 1 | 01-03-2005 4:33 PM |
| | Thread Tools | Display Modes |
| | #1 (permalink) |
| Member | Fixing Screws for Panasonic TV and Next stand
Hi, didn't know whether to post this here or in the TH42PZ80 thread so I've done both (this is quite possibly wrong but hopefully the mods will put it where it belongs!) I bought this stand (I think it might be a called a cantilever stand?) http://tinyurl.com/5lfmgf from Next, for my new TH42PZ80. I've worked out (eventually) where the four mounting holes are on the back of the TV but there are no screws in them and no screws came with the stand or the TV ![]() Can anyone advise on what size/length screws I need and where would I get them from? Do all TVs use pretty standard size screws? |
| Bookmarks |
| Tags |
| fixing, panasonic, screws, stand |
| Thread Tools | |
| Display Modes | |
