How to dismount a Panasonic Plasma cabinet ?? URGENT !!!
Old 28-08-2008, 8:43 PM   #1
5,657, Level: 17
Points: 5,657, Level: 17 Points: 5,657, Level: 17 Points: 5,657, Level: 17
Thanks: Gave 4, Got 1
Hello Everyone,
Urgent help as i am moving out of my flat tomorrow. I have a 42 inch plasma from Panasonic which i bought with the big floor plasma cabinet from Panasonic (as in here : http://www.bradburysappliances.co.uk...s/th42px60.jpg) . How do you unhook the plasma from the cabinet ??? it seems to be stuck on it ??
Please, please, someone help ?
Ta
Old 28-08-2008, 8:54 PM   #2
3,688, Level: 14
Points: 3,688, Level: 14 Points: 3,688, Level: 14 Points: 3,688, Level: 14
Thanks: Gave 2, Got 0
Re: How to dismount a Panasonic Plasma cabinet ?? URGENT !!!
the stand has a metal spike that goes up it to the tv at each end. behind the tv at each end in the bottom corner there is one screws that needs to be removed, the tv will just lift off.
see the image in this thread:
http://www.avforums.com/forums/showthread.php?t=536860
Old 28-08-2008, 9:58 PM   #3
5,657, Level: 17
Cheers....
That's great !!! thank you so much for your quick help.
So we are clear, the screws you are mentioning are the ones at the bottom of the spikes itself 5one for each spike) or the ones on the plasma itself alongside what should be the spike placement "within" the plasma ?? If it is the ones on the plama side, there are 2, one at the top of the spike "placement" and one at the bottom of the spike "placement". Should i unscrew both then ?
thanks a lot, you are savin my day
Old 29-08-2008, 8:47 AM   #4
3,688, Level: 14
the screws go through the back of the plasma into the holes of the spike, mine is a 37" panasonic and only has one screw, the 42" may have 2!
