Sound Organisation Z545 weight limit
Old 14-08-2008, 3:11 PM   #1
conman's Avatar
3,993, Level: 14
Points: 3,993, Level: 14 Points: 3,993, Level: 14 Points: 3,993, Level: 14
Thanks: Gave 11, Got 48
I wonder if anyone would have old manual or know what is the weight limit on each shelf and total limit.
Their website only gives me dimensions.
Model:
Sound Organisation Z545, 5 tires, each have tough glass (4-6mm).
I would like to put 2 heavy weight amps on it, they weight 20 kg. and 30 kg. plus DVD player and pre-amp (10 kg together)
I dont want to risk buying and break it at the end.
cheers
Old 17-08-2008, 9:54 PM   #2
conman's Avatar
3,993, Level: 14
Re: Sound Organisation Z545 weight limit
It might be too late... but i already put over 60 kg over it.... i even test it before putting anything on by sitting on it... I weight around 90 kg.
so far so good... but anyone with the instruction out there please ... i NEED one
