Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
John Lewis Maharani Corner TV Unit
John Lewis Stowe TV Unit
John Lewis Matilda Bar Chair, Black
The Furniture Factory Worcester TV En...
Ellis Entertainment Unit, Light
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
 More...Prices updated November 22nd at 8:30pm and include delivery.
HTPC case with 12cm fans/mounts but ATX size? poggs Home Cinema PCs 7 18-06-2008 10:25 AM
Mounting my Sony 52x3500 on the wall. ChiefMFG.com wall mounts & UK suppliers?? DTBK Flat Screen TV Brackets and Mounts 3 01-04-2008 3:51 PM
Ergotron Wall Mount for Panasonic 42PX60, any good? read1976 AV Stands, Cabinets, Seating and Furniture 2 25-04-2006 8:12 AM
Are all wall mounts the same? gad Flat Screen TV Brackets and Mounts 0 12-01-2006 8:51 PM
Wall mounts. Johnny Thunder Speakers 1 09-02-2005 11:15 PM
Old 13-08-2008, 3:05 PM   #1 (permalink)
Thanks: Gave 4, Got 7
Ergotron Cast Alloy Wall Mounts? Anyone had much experience with them?
Just thought I'd ask... Did a quick search which didn't come up with much.
I was looking at one of these to mount a Panasonic TH50PZ81 onto red brick:
http://www.ergotron.com/Products/Wal...B/default.aspx
They look quite nice.
or as an alternative to the fancy cast job above, this:
https://www.avsupports.com/general/g...cket_1390.html
Apart from a small cost saving on the second wall mount can anyone think of any other advantages? Possibly it has a slightly wider footprint on the wall to spread to weight? Although they are both rated up to 79/80kg
Thoughts anyone?
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
pedwar is offline   Reply With Quote
Old 14-08-2008, 8:30 AM   #2 (permalink)
Assured Advertiser
Thanks: Gave 0, Got 22
Re: Ergotron Alloy Case Wall Mounts? Anyone had much experience with them?
Hi They both do the same job and work in a very simular way, you fix the backplate to the wall fix the 2 brackets to your TV and hang it in the wall its a very simple proven method.
Once the TV is on the wall you will not see the bracket anyway, as long as its black it will merge in to the black TV case when viewed from the side, but you will have to have your head against the wall to see it.
So go for the cheapest (I have tried to be as un-biased as possible)
If you go for our bracket don't forget to use the discount code 422.
AVSUPPORTS is proud to be an Assured Advertiser on AV Forums
Regards Tony (Technical Support)
AVSupports BLOG FOR SPECIAL OFFERS
Specialists in - TV Brackets, TV Stands, TV Furniture : Help Line 0800 011 4584
avsupports is offline   Reply With Quote
Old 16-08-2008, 12:32 AM   #3 (permalink)
I think you're right.. not much in it.
One question, you say as long as it's black it won't be seen which I agree with, on the description of the AVS-R005SVL it says "Silver durable finish." but the pics look black
Could you confirm if they are black?
Cheers!
(\__/)
Old 16-08-2008, 5:45 AM   #4 (permalink)
Assured Advertiser
Hi I thought that they were Black I need to check with the warehouse on Monday weill get back to you as soon as I can confirm.
Sorry for the confusion.
Old 18-08-2008, 7:34 AM   #5 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
http://www.ergotron.com/Products/Wal...B/default.aspx DOnt like the look of that as the back plate is low down on the screen, where all the cables connect so much higher risk of fouling the cables or crushing them on mounting
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 18-08-2008, 9:30 AM   #6 (permalink)
Assured Advertiser
Hi PedwarSorry I made an error the brackets are in Silver the clearance from the wall is only 35mm so you should not be able to see much of the bracket.
Apologies for the confusion.
alloy, case, ergotron, experience, mounts, wall
