Tall speaker stands for rears
Old 11-08-2008, 12:05 PM   #1
atr1981's Avatar
5,147, Level: 16
Points: 5,147, Level: 16 Points: 5,147, Level: 16 Points: 5,147, Level: 16
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 10, Got 39
Hi Guys,
I'm under the impression that the rear speakers should be slightly behind me, facing each other and a few feet above my listening position.
Now, i'm moving into a new flat and if this is the case will be looking at getting some tall stands good enough to support a set of MA BR1's.
I have Atacama Nexus 6's for the fronts. Would the Nexus 10's be high enough to give the speakers enough height ? I don't want the a few feet above me as I think they will look out of place but high enough to work.
Any other suggestions for stands ?
Thanks.
Old 19-08-2008, 10:10 PM   #2
1,642, Level: 9
Points: 1,642, Level: 9 Points: 1,642, Level: 9 Points: 1,642, Level: 9
Thanks: Gave 1, Got 1
Re: Tall speaker stands for rears
i'm currently using Apollo's A/1 900mm for my rear speakers with bookshelf missions sitting on top. Provide a decent height, not expensive, and are actually pretty well made. The single tubed stands should prove more than adequate for rear speakers.
http://www.a1-sound.co.uk/product/ap...peaker-stands?
Old 20-08-2008, 12:13 AM   #3
davepuma's Avatar
32,004, Level: 43
Points: 32,004, Level: 43 Points: 32,004, Level: 43 Points: 32,004, Level: 43
Activity: 41.3%
Activity: 41.3% Activity: 41.3% Activity: 41.3%
Thanks: Gave 396, Got 2,175
Use the Atacama Nexus 10 myself.
Old 20-08-2008, 12:15 AM   #4
18,923, Level: 33
Points: 18,923, Level: 33 Points: 18,923, Level: 33 Points: 18,923, Level: 33
Activity: 15.5%
Activity: 15.5% Activity: 15.5% Activity: 15.5%
Thanks: Gave 76, Got 186
me too. I think Nexus 10's are exactly the right height, and pretty stable for a stand this tall.
Old 20-08-2008, 5:34 PM   #5
3,435, Level: 13
Points: 3,435, Level: 13 Points: 3,435, Level: 13 Points: 3,435, Level: 13
Nexus 10's all the way! I have some and have never looked back!
Old 23-08-2008, 5:46 PM   #6
3,849, Level: 14
Points: 3,849, Level: 14 Points: 3,849, Level: 14 Points: 3,849, Level: 14
Thanks: Gave 9, Got 7
Yep, got nexus 6 at the front, just ordered the 10's as going from wall brackets down to proper stands now.
