Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
Caxton royale wide tv entertainment unit
Metropole Ocean TV entertainment unit
Caxton Coniston wide TV entertainment unit
The Furniture Factory Worcester TV En...
Caxton Coniston wide TV entertainment...
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
Wall mountable TV entertainment unit
 More...Prices updated November 22nd at 11:30pm and include delivery.
centre speaker stand Carl fitz Speakers 3 20-03-2006 10:12 AM
centre speaker stand pickle AV Stands, Cabinets, Seating and Furniture 13 13-06-2004 10:20 AM
Centre Speaker Stand staffspeted Speakers 0 19-01-2003 7:36 PM
Old 08-08-2008, 3:10 PM   #1 (permalink)
ramjam55's Avatar
Thanks: Gave 2, Got 20
Afetrnoon all,
Due to a recent change in my setup, I now find myself with no space for my centre speaker. The room it's in means the only solution is to use a centre stand, but it appears these are like hens teeth. Does anyone know where I can find such a stand ? Searching google and these forums have so far come up blank. It appears there's no great demand for these stands.
Any help would be appreciated before I get my hammer and nails out and make my own
ramjam55 is offline   Reply With Quote
Old 09-08-2008, 6:18 PM   #2 (permalink)
NobleBenj's Avatar
Thanks: Gave 47, Got 23
Re: Centre Speaker Stand
Originally Posted by ramjam55 View Post
Afetrnoon all,
Thats why I'm here too! this is my stand (http://www.amazon.co.uk/Optimum-Elmo...8305709&sr=1-3) as you can see it doesn't have an independent center speaker stand so the only place it can go is above the plasma but how? I can't find anything on goggle either.
we cant be the first people with this problem.
*Also, it cant go on the wall above the TV because theres a window there help anyone?
P.S sorry I cant help you ramjam
Pioneer PDP-LX5090D | Yamaha RX-V1900 | Quad L-ite 5.1 | Pioneer BDP-51FD | Thomson Sky HD | Sony PS3 60gb | Xbox 360 Elite | Logitech Harmony 885
PSN: GookaDuke | XBOX LIVE: NobleBenj |
NobleBenj is offline   Reply With Quote
Old 10-08-2008, 4:22 PM   #3 (permalink)
Thanks: Gave 16, Got 14
What kind of budget do you have? Monitor Audio do some center speaker stands for their Gold and Platinum ranges, but I see no reason these can't be used with other speakers. They're not cheap though.
http://www.hifix.co.uk/shop.lasso?sh...pment%20Stands
Alternatively, try 2 normal speaker stands side-by-side and have the center speaker placed across both platforms. This is probably what I'm going to do once my new AV rack arrives.
| Pioneer KRP-500M | Sony BDP-S350 | Sony STR-DA3400ES | 3x Audiolab 8000M | Monitor Audio BR2 | BRFX | BRLCR | BK Monolith - DF | My DIY Build Thread
AndyST is offline   Reply With Quote
Old 12-08-2008, 12:06 PM   #4 (permalink)
ramjam55's Avatar
Hi Andyst,
Thats exactly what I'm after, but at £150 it'll cost more than my speaker, so would have to rule that out. Shame as it'll do the job for me. Maybe I'll have to get the hammer and nails out afterall
Old 14-08-2008, 5:02 PM   #5 (permalink)
Thanks: Gave 3, Got 1
What size is your TV base?
The base of my TV is pretty much the same size as my centre speaker and I stand my TV on top of the speaker (although it has curved rear that overhangs a few cm's).
I also saw a thread a while ago where someone couldn't find a stand so built one one that utilised the rear wall mount screws on the TV. He got a sheet of metal and bent it so that it held the speaker above the TV and screwed into the mount holes.
David_S is offline   Reply With Quote
Old 15-08-2008, 11:12 AM   #6 (permalink)
Thanks: Gave 19, Got 4
I can't tell if you guys have the same problem as me, so apologies if i seem to ask the same thing
Basically i want a stand that will raise my tv enough to slide the centre speaker in underneath and support the tv.
At the moment the tv sits on the top shelf and the centre speaker sits on the first shelf under, but it's a bit low and i want to raise it. Does anything exist like that? Obviously it has to be robust enough so my tv doesn't take an unexpected topple!
EYES Panasonic TH-42PX80B | Sky HD
EARS Sony DG820 Silver | Mordant Short 5.1 3 series
FINGERS PS3 120 HDD | Wii | iPhone 3GS
dpgwhiteley is offline   Reply With Quote
Old 15-08-2008, 11:44 AM   #7 (permalink)
ramjam55's Avatar
Hi chaps,
My centre is a Kef Q9c which is curved so no way it can go on top of it. I has thought of raising up my plasma using a MDF frame and putting it underneath. My other alternative is to change my centre speker to a kef 9000 ACE which will fit in from of my plasma.
Old 20-08-2008, 11:05 AM   #8 (permalink)
Hi, I started a thread myself, but this is exactly what I'm looking for too. My LCD is in the corner of the room, so can't put the centre speaker on the wall, and so want to get it above the screen using an arm that screws into the wall mount holes and then holds the speaker. If anyone finds a product, or knows someone who can make one please post up the details. Cheers.
music4mybumhole is offline   Reply With Quote
centre, speaker, stand
