Stacking Alphason AMBRI ABR1100-LO TV Cabinet?
Old 01-08-2008, 10:53 PM   #1
3,105, Level: 13
Points: 3,105, Level: 13 Points: 3,105, Level: 13 Points: 3,105, Level: 13
Thanks: Gave 23, Got 0
Hi have been looking at the Alphason AMBRI ABR1100-LO TV Cabinet and really like this cabinet but 1 isn't going to house all my kit. Unfortunately I only have 140cm width so don't have the luxury to have 2 side by side. Has anyone mounted 1 on top of the other? Can anyone see a problem with this? Appreciate if someone could help me with this as I need to order a cabinet within the next few days. Other alternative looked at is Ikea Besta range but they don't do this in black only black/brown so Alphason stacked would be first choice if it works.
Thanks very much.
Old 02-08-2008, 9:35 AM   #2
12,192, Level: 26
Points: 12,192, Level: 26 Points: 12,192, Level: 26 Points: 12,192, Level: 26
Thanks: Gave 1,130, Got 518
Re: Stacking Alphason AMBRI ABR1100-LO TV Cabinet?
Only immediate problem will be the wheels, so they will have to be omitted from the top one. One other thing to watch out for is the door drop, as it`s the whole of the front so you might need to elevate it enough to be able to open the thing up.
newtothis (03-08-2008)
Old 02-08-2008, 10:25 PM   #3
3,105, Level: 13
Of course - forgot the wheels!
Old 03-08-2008, 12:47 PM   #4
1,888, Level: 10
Points: 1,888, Level: 10 Points: 1,888, Level: 10 Points: 1,888, Level: 10
Thanks: Gave 41, Got 7
Just had a look at mine and the top door would foul the bottom door if you tried to open it with the bottom door closed. You could put a spacer between to overcome this but i dont think it would look that good.
Old 03-08-2008, 7:21 PM   #5
3,105, Level: 13
Huge thanks John B. So hard to imagine these things when you are buying online.
Back to the drawing board on the cabinet!
Cheers so much
Amanda
