Please recommend me a TV stand that accommodates the centre speaker.
Old 30-07-2008, 5:22 PM   #1
Hades's Avatar
32,042, Level: 43
Points: 32,042, Level: 43 Points: 32,042, Level: 43 Points: 32,042, Level: 43
Activity: 4.1%
Activity: 4.1% Activity: 4.1% Activity: 4.1%
Thanks: Gave 1,076, Got 1,042
My current stand is shown below and the issue I have is that I want the centre speaker to sit on a shelf beneath the TV.
Does anyone have any recommendations different to the ones below? Also does anyone have theirs set-up in a similar way using something like I have shown below? If you have a good stand with your centre speaker on and could post a picture and details of the stand, then it would be very much appreciated.
Techlink Avatar PTV3
Alphason ADP3/96-PB
FS205 Universal
Old 30-08-2008, 3:07 PM   #2
Hades's Avatar
32,042, Level: 43
Activity: 4.1%
Re: Please recommend me a TV stand that accommodates the centre speaker.
Any feedback would be appreciated
Old 30-08-2008, 10:49 PM   #3
region1's Avatar
2,000, Level: 10
Points: 2,000, Level: 10 Points: 2,000, Level: 10 Points: 2,000, Level: 10
Thanks: Gave 3, Got 1
contact Kenmark UK , based in North London.
They have amazing stands for all sort of layouts , and good prices
Old 31-08-2008, 12:19 AM   #4
THE_FORCE's Avatar
21,983, Level: 36
Points: 21,983, Level: 36 Points: 21,983, Level: 36 Points: 21,983, Level: 36
Activity: 12.6%
Activity: 12.6% Activity: 12.6% Activity: 12.6%
Thanks: Gave 1,653, Got 1,037
Hi Gazza !
It's a real pain trying to find a stand that can accomodate a centre speaker like you're after. But maybe you should have a look at an alternative like these ?:
They're from Quatropi, and they've got loads more here:
http://www.quatropi.com/c-126-tv-stands.aspx
Hope this helps mate.
Old 31-08-2008, 10:47 AM   #5
Hades's Avatar
32,042, Level: 43
Activity: 4.1%
Do they a website? I would need to see actual pictures and a trip to London is out of the question from North Yorkshire
Old 31-08-2008, 10:48 AM   #6
Hades's Avatar
32,042, Level: 43
Activity: 4.1%
Originally Posted by THE_FORCE View Post
Hi Gazza !
Thanks for that but way too big for me and not really my cup-of-tea to be honest.
Old 05-09-2008, 4:19 PM   #7
Getinthehole!'s Avatar
3,164, Level: 13
Points: 3,164, Level: 13 Points: 3,164, Level: 13 Points: 3,164, Level: 13
Thanks: Gave 61, Got 26
Just ordered a Spectral PL171 expensive but quality german engineering
Old 05-09-2008, 5:58 PM   #8
Hades's Avatar
32,042, Level: 43
Activity: 4.1%
Flaming eck, I could get a Samsung 50" for that and still have some change
Old 06-09-2008, 9:44 AM   #9
3,164, Level: 13
Or buy a new family car for the rest of the system
I have been working on this for a while
Monitor Audio GS20
Monitor Audio GS LCR
Monitor Audio RS-FX
Monitor Audio RSW12
DENON AVR 3808
DENON 2500 BT
DENON ASD1R
PIONEER LX5090
SKY HD
PS3
Spectral PL171
Old 08-09-2008, 8:13 AM   #10
3,565, Level: 14
Points: 3,565, Level: 14 Points: 3,565, Level: 14 Points: 3,565, Level: 14
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 1, Got 2
Just ordered one of these to accomodate a Onkyo amp, Panasonic DVD and Sky HD box plus a Kef Q9C center speaker.:-
Came to around £300 as the model shown doesn't have a deep enough base to house the amp so I ordered one with a deeper one.
Only thing is it as actually cost me £850 as the wife has had to have a new carpet as well!!!!
Last edited by inzaman; 16-09-2008 at 8:42 AM. Reason: Image breaks forum rule no. 9
Old 15-09-2008, 9:13 AM   #11
6,583, Level: 19
Points: 6,583, Level: 19 Points: 6,583, Level: 19 Points: 6,583, Level: 19
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 98, Got 107
I have the third one in your first post. Have a look at the link in my sig for pics. It's fantastic value for money and the quality of the final unit really belies the price tag.
Hades (15-09-2008)
Old 16-09-2008, 8:01 AM   #12
3,565, Level: 14
Activity: 1.5%
As posted above purcahsed and now received one of these:-
And god what a nightmare setting it up. To be fair it wasn't really the stands fault either. I have a Onkyo amp to accomodate (bottom shelf and happily has about 2" air flow from shelf which has stopped the amp clicking).
Now the problem. Wanted to put my Sky HD plus Panasonic DVD on centre shelf. Tried it BUT then found that if I did that my Kef Q9C centre speaker which has that annoying bulge at the top would interfere with the viewing iof the 42" plasma.
So the speaker had to go on the centre shelf BUT it would only fit if I turned the shelf upside down and the metal support was at the top. Then the Sky + DVD fits on the top shelf. Which looks sort of ok except the component cables I use were slightly too short.
Oh and the QED bi wire cable which I had laid under the carpet and coming out of a 1" hole I drilled in the base of this stand was also very tight.
Let's just say a lot of swearing and three hours later it is done. I'm just getting used to it now.
Old 16-09-2008, 11:32 AM   #13
6,583, Level: 19
Activity: 2.3%
Which did you order?
Old 16-09-2008, 2:28 PM   #14
3,565, Level: 14
Activity: 1.5%
Sorry poison jam - link to picture keeps on getting lost in post.
URL link here:
http://www.avrabbit.com/product-Orig...stand-614.html
Last edited by inzaman; 16-09-2008 at 3:32 PM. Reason: Images break forum rule no. 9
Old 16-09-2008, 3:33 PM   #15
inzaman's Avatar
22,352, Level: 36
Points: 22,352, Level: 36 Points: 22,352, Level: 36 Points: 22,352, Level: 36
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 126, Got 543
Thats because the images break forum rule no. 9
Old 16-09-2008, 5:05 PM   #16
mooperman's Avatar
10,213, Level: 24
Points: 10,213, Level: 24 Points: 10,213, Level: 24 Points: 10,213, Level: 24
Activity: 22.0%
Activity: 22.0% Activity: 22.0% Activity: 22.0%
Thanks: Gave 1,772, Got 484
i have the FS205 and its a superb stand...
Old 16-09-2008, 6:03 PM   #17
Hades's Avatar
32,042, Level: 43
Activity: 4.1%
If it were not for having a noisy Sky HD box then I would buy it now.
Old 16-09-2008, 10:38 PM   #18
6,583, Level: 19
Activity: 2.3%
I take it you have seen the thread on this where I and others post lots of info and pics on it?
Old 17-09-2008, 8:46 AM   #19
3,565, Level: 14
Activity: 1.5%
Ooops , quickly searches for rule book!
Old 21-09-2008, 1:16 PM   #20
1,943, Level: 10
Points: 1,943, Level: 10 Points: 1,943, Level: 10 Points: 1,943, Level: 10
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 2, Got 0
Mooperman,
I am also looking for the FS205 but I live in France and I am having difficulty getting hold of a supplier. Do you have a manufacturers name?
Old 21-09-2008, 3:16 PM   #21
Hades's Avatar
32,042, Level: 43
Activity: 4.1%
Does this help?
Old 21-09-2008, 3:19 PM   #22
1,943, Level: 10
Activity: 1.4%
I already had that link thanks but it still does not mention the manufacturers name, only the model.
Old 21-09-2008, 8:03 PM   #23
Hades's Avatar
32,042, Level: 43
Activity: 4.1%
Why not email them and ask?
Old 22-09-2008, 1:13 AM   #24
4,388, Level: 15
Points: 4,388, Level: 15 Points: 4,388, Level: 15 Points: 4,388, Level: 15
Activity: 4.7%
Activity: 4.7% Activity: 4.7% Activity: 4.7%
Thanks: Gave 35, Got 50
Gazza
Have you tried Optimum stands?
Here's a link:
http://www.standanddeliver.com/acata...tv_stands.html
They're modular in design, so you decide on the rod finish and height to suit your needs.
I have the AV 400 with 230mm rods in Light Ash - looks lovely!
Derek
Old 22-09-2008, 7:58 AM   #25
Hades's Avatar
32,042, Level: 43
Activity: 4.1%
Because of the noise Sky HD makes, I am putting this venture on hold for now. Its better where it is for now and not out in the open.
