Is this really so difficult to find?
Old 13-05-2008, 12:41 PM   #1
1,914, Level: 10
Points: 1,914, Level: 10 Points: 1,914, Level: 10 Points: 1,914, Level: 10
Thanks: Gave 6, Got 16
All I want is stand that is 1250mm long or more and has 2 shelves (internally, I suppose you could call it 3 shelved), has no dividing thing in the middle, has a bottom to middle shelf height of at least 200mm prefereably more, a height from middle shelf to top of at least 170mm and depth of around 500mm. I've spent so long looking around and nothing seems to fit the bill, has anyone seen something that will?
Old 13-05-2008, 1:23 PM   #2
stuart07970's Avatar
5,654, Level: 17
Points: 5,654, Level: 17 Points: 5,654, Level: 17 Points: 5,654, Level: 17
Thanks: Gave 89, Got 109
Re: Is this really so difficult to find?
you need a custom du-oppli
Old 13-05-2008, 1:35 PM   #3
vex vex is offline
10,371, Level: 24
Points: 10,371, Level: 24 Points: 10,371, Level: 24 Points: 10,371, Level: 24
Activity: 3.7%
Activity: 3.7% Activity: 3.7% Activity: 3.7%
Thanks: Gave 27, Got 252
Have you tried www.homecinemastands.co.uk as an assured advertiser on here?
They certainly seem to have an extensive list.
V.
Old 13-05-2008, 2:35 PM   #4
menz83's Avatar
Thanks: Gave 224, Got 203
Falls a bit short of your needs but a very popular stand with users in this forum.
http://www.allcam.biz/catalog/produc...roducts_id=584
There is a thread about it here. Just ordered one myself, although havent set it up yet.
Black glass Cantilever 60" stand
Old 13-05-2008, 8:33 PM   #5
4,921, Level: 16
Points: 4,921, Level: 16 Points: 4,921, Level: 16 Points: 4,921, Level: 16
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 23, Got 15
I'm looking for something similar, I have 3 items I want next to each other (Sky+ - Centre speaker - PS3 - totaling 1170mm) so with gaps 1250mm would be ideal. I'd like the top shelf to be at least 140mm gap and the bottom at least 180mm for my Onkyo 606 and the whole thing to be about 500mm deep.
So if you see anything please post links!
Old 13-05-2008, 8:41 PM   #6
4,921, Level: 16
Activity: 3.0%
ikea no longer stock the oppli
Old 26-05-2008, 7:32 AM   #7
1,914, Level: 10
Hi, I found a bought a stand in costco, don't have the sizes with me, i'll try and post them later.
Old 27-05-2008, 7:08 AM   #8
1,914, Level: 10
Forgot to post details last night, basically its the same as this except the legs are a dark coloured wood http://www.whalenfurniture.com/products/xl1.html
I'm quite impressed by the stand it was only about £150, it comes with 2 back posts so you can either have the tv on the top of the stand, mount it on the back post or use the bracket to wall mount the tv.
Old 29-05-2008, 9:20 PM   #9
4,921, Level: 16
Activity: 3.0%
Nice find
