Serano Stand !! Will It Support?
Old 06-05-2008, 9:06 PM   #1
9,988, Level: 23
Points: 9,988, Level: 23 Points: 9,988, Level: 23 Points: 9,988, Level: 23
Thanks: Gave 6, Got 25
Hi guys, ive got a Serano Black Glass Stand, model SR1050B. Ive checked the specs below...
http://www.currys.co.uk/martprd/stor...category_oid=#
max weight is 150kg, so im assuming its more then strong enough to hold my new toshiba 42" XV505DB Tv, along with my Yamaha Amp, B&W Center and an xbox and sky box, im sure the weight of all them is not 150kg, just after some reasurance really that it wont collapse.
Cant believe the stand is £220, i brought it new about a year ago for £150 from same place.
Old 06-05-2008, 9:34 PM   #2
social_lurker's Avatar
3,452, Level: 13
Points: 3,452, Level: 13 Points: 3,452, Level: 13 Points: 3,452, Level: 13
Thanks: Gave 55, Got 72
Re: Serano Stand !! Will It Support?
That should be fine. The telly cant be much more than 30-40kg, the amp 10kg and the other bits will be less than that.
The stands are priced up, so that when they are purchased with a telly you can offer big discounts (and the customer thinks they get a great deal). Typically, most stands are between £80-100 when you buy a telly at the same time, i.e. half price or so.
Old 27-05-2008, 10:36 PM   #3
3,918, Level: 14
Points: 3,918, Level: 14 Points: 3,918, Level: 14 Points: 3,918, Level: 14
Thanks: Gave 53, Got 12
I've got my eye on one of these stands, are they good qulaity ? Hoping to pair one up with a 42" Panasonic plasma, centre speaker and HD-DVD player.
Thanks.
