TV stand ( picture included)
Old 02-05-2008, 12:16 PM   #1
2,486, Level: 11
Points: 2,486, Level: 11 Points: 2,486, Level: 11 Points: 2,486, Level: 11
Hi Guys
Im looking for this lcd stand i seen on Amazon
http://www.amazon.co.uk/b/ref=amb_li...pf_rd_i=283926
Its not for sale but would like to find out where i could buy it in the UK
Old 02-05-2008, 12:24 PM   #2
ANGUZ's Avatar
5,348, Level: 17
Points: 5,348, Level: 17 Points: 5,348, Level: 17 Points: 5,348, Level: 17
Thanks: Gave 55, Got 15
Re: TV stand ( picture included)
If you are any good In the D.I.Y. dept, I`m sure you could knock a stand like that up pretty easy, you can buy the metal rods/poles from most big D.I.Y. stores and the wood would be easy to come buy, and the beuaty of a home made one is you can make It to fit your gear.
Old 02-05-2008, 12:43 PM   #3
2,486, Level: 11
Na no gd at D.I.Y.
Old 02-05-2008, 8:02 PM   #4
inzaman's Avatar
22,356, Level: 36
Points: 22,356, Level: 36 Points: 22,356, Level: 36 Points: 22,356, Level: 36
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 126, Got 543
Moved to Stands etc
