Has anyone seen a Blok 3000 in the flesh?
Old 23-04-2008, 6:38 PM   #1
7,549, Level: 20
Points: 7,549, Level: 20 Points: 7,549, Level: 20 Points: 7,549, Level: 20
Thanks: Gave 69, Got 273
I need an AV cabinet and the Blok 3000 is the only one which "ticks all the boxes" unless I get something custom made. Trouble is, although I can buy one on-line I can't get to see one in the flesh. As it's 800 quid, I'd like to know what the build quality and finish is like before parting with my hard earned cash. Does anyone have any comments to make?
Many thanks.
Old 23-04-2008, 9:20 PM   #2
furs307c's Avatar
3,081, Level: 13
Points: 3,081, Level: 13 Points: 3,081, Level: 13 Points: 3,081, Level: 13
Thanks: Gave 0, Got 12
Re: Has anyone seen a Blok 3000 in the flesh?
Havent seen that particular unit, but if its the same quality as their other stuff then you should be fine
Old 25-04-2008, 8:24 AM   #3
7,549, Level: 20
Thanks for that. Anyone else actually seen one?
Old 25-04-2008, 1:05 PM   #4
greeze's Avatar
3,453, Level: 13
Points: 3,453, Level: 13 Points: 3,453, Level: 13 Points: 3,453, Level: 13
Thanks: Gave 10, Got 5
I've seen one and have one on order (in walnut with glass-fronted doors) . I had a good look at it in the shop (Hughes TV & Audio - Lowestoft) and was very impressed with the build quality . A well-built, solid piece of furniture delivered fully assembled too (none of this flat-pack stuff!)
It's expensive sure, but the good stuff always is (£725.00 delivered from Hughes. Good price!)
Get it, I don't think you'll be disappointed.
Old 25-04-2008, 1:11 PM   #5
7,549, Level: 20
Great stuff. Many thanks indeed. That is a good price. Best I've come accross is £799.
Old 29-04-2008, 5:48 AM   #6
greeze's Avatar
3,453, Level: 13
A bit of a development with this; the cabinet is going to be delayed until the end of June ! This is due to Blok having a shortage of materials from one of their suppliers.
I've still got the order placed but have had to get an 'orrible cheapy stand from Argos so I can set all my gear up.
I've searched around on the net but have been unable to find any shops with actual stock (they all seem to order direct from Blok and not keep anything in stock themselves)
Old 29-04-2008, 9:11 AM   #7
jameslindsey's Avatar
4,464, Level: 15
Points: 4,464, Level: 15 Points: 4,464, Level: 15 Points: 4,464, Level: 15
Thanks: Gave 14, Got 22
I was going for the Blok, but felt it was a bit too woody. I bought the stands unique ultimate cabinet instead which I feel has a bit more style about it and roughly the same price. You lose the drawer but the centre speaker section is a little cleverer. Build qulaity is superb, it's a very heavy beast. I also managed to source some casters which I feel is important if you cant get round the back as otherwise you'll need to dismantle everything to move it or plug stuff in.
Old 29-04-2008, 1:48 PM   #8
greeze's Avatar
3,453, Level: 13
I did have a look at the Stands Unique AV10 Cabinet. Infact it was my first choice until I realised that my amp wouldn't fit properly (cabinet lacks sufficent depth). Also, my 50" Pioneer would 'overhang' the cabinet; a look that I, personally, dislike.
Lovely piece of furniture though and I love the idea of the child-proofing kit (would be handy ).
I'm just gonna have to bite the bullet and wait for my Blok to be delivered...
Old 29-04-2008, 5:15 PM   #9
7,549, Level: 20
Interesting about having to wait - good job I'm not in a hurry. Checked out the Stands Unique, both the Ultimate and AV10. Unfortunatley, both too small and I need to hide the electronics when not in use so I need solid doors. Thanks anyway.
Old 29-04-2008, 6:02 PM   #10
4,464, Level: 15
Supprised the ultimate high is too small. Unless you've got loads of kit.
My amp is very large and just fits I was also worried about the speaker which is exactly 50cm tall. Without the door option components could be a couple of inches bigger. Happy to get a tape measure out if there is any dimension you want me to check.
Old 29-04-2008, 8:47 PM   #11
7,549, Level: 20
It's a width and "hiding away" thing. Complicated but has to be low and wide (also, everything has to be hidden when not in use). With the Blok, I can have the centre on it's side, behind the grill with components either side and either black (not tinted) glass or solid doors.
Thanks for the offer of the tape measure but the Blok is the only one that ticks all the boxes. Or maybe custom made, which I am also considering.
Old 30-04-2008, 7:36 AM   #12
4,464, Level: 15
No probs.
Not as nice looking as the Blok but the Ikea Besta shelving can be configured to be as good as the blok and about a quarter of the price. you can choose door types etc. That was my fallback plan if the SU didn't work out. Their www site has a shelving builder thing that might sort you out.
Old 30-04-2008, 6:32 PM   #13
7,549, Level: 20
Hi again,
Yes, I've looked at Ikea - don't think there's anything I haven't looked at . Have to say, I'm a fan. Their stuff is really sturdy and good quality finish. Excellent value for money in my opinion.
On the other hand, I'm about to spend a shed load of money on speakers and AV gear. The furniture is also part of the same "package". I'd rather not "spoil the ship for a halpennyworth of tar". So, I think it is going to still be Blok or custom made.
Many thanks for taking the time. I appreciate your efforts.
Old 03-05-2008, 5:20 AM   #14
greeze's Avatar
3,453, Level: 13
At the danger of hijacking your thread deckingman, I just wanted to update you on the Blok situation and my current 'workaround'.
Blok are apparently waiting for glass and fittings from one of their suppliers, hence the delay (I was told of this from a guy in the shop). I still have mine on order and, frustratingly, still have all my kit laying around in the boxes . So, I went out and bought a cheap Argos stand/unit that would be long enough to take the plasma but it turned out to be totally s**t. It cost £29.99 and must have cost all of 20p to make!
The idea was to set everything up on the 'Argos Special' and then when my Blok arrived just swap it all out and bin the old stand. However, the stand was woefully inadequate with no strength and no matter how I looked at it, I couldn't see any way of making it stonger without a full re-build (it's wood and plastic ). There's no way I'm putting my plasma and amp into that!
Anyway, after much scratching of head, I'm going to build my own temporary cabinet, strong enough to take all my kit and with much the same dimensions as the Blok, out of 18mm MDF. I'm going to sort out the construction drawings this morning and hopefully get the material cut this afternoon and get it all together tonight. I'll post some photo's if you're interested?
Old 03-05-2008, 8:18 AM   #15
7,549, Level: 20
HI,
Thanks for that. Fortunatley (or unfortunatley) I'm not in a hurry. I have a large Beaver and Tapley base unit which currently houses my gear and the TV. Long story but before I can put in place my major upgrade, I have to sort out 'er in door's own major upgrade to the en-suite bathroom. Only when that's done, can I spend the dosh on my toys. The Tapley unit will have to go eventually because a) it is too long (over 2 metres) and limits the space I need for the new floorstanding speakers and b) although I've hacked the back about, there won't be enough ventilation for the new AV amp.
So I can wait (in fact, frustratingly, I have no choice). I may still look at custom made because we still need to get something to house all the CDs and DVDs which also have to be "out of site" (another long story).
Many thanks for the info though. I'll expect to see an Argos stand listed on Ebay. Best of luck with the DIY version.
Old 04-05-2008, 5:39 AM   #16
greeze's Avatar
3,453, Level: 13
Here it is! My Blok 'stand-in'
Total cost= £35.00. To be binned when the Blok 3000 cabinet turns up. It's a little rough-and-ready but it'll do for now. At least I can get my AV gear setup this afternoon
Old 17-09-2008, 6:03 PM   #17
thudspud's Avatar
5,619, Level: 17
Points: 5,619, Level: 17 Points: 5,619, Level: 17 Points: 5,619, Level: 17
Thanks: Gave 21, Got 57
Did you ever get your blok 3000?, how is it?
Looking at one myself.
Chris
Old 17-09-2008, 7:53 PM   #18
7,549, Level: 20
Er....... nope.
Haven't looked into it for a while. Not sure what the supply situation is for Blok is now. Currently getting some quotes for something similar but bespoke. I quite fancy the idea of having the doors retract back into the cabinet when open, a bit like the Quadraspire QAV. So I'm looking into a cross between the Blok and Quadraspire but with a finish to match my speakers. If this is going to be an arm and a leg, then I'll look again at the Blok.
Old 17-09-2008, 10:47 PM   #19
thudspud's Avatar
5,619, Level: 17
thanks for the reply, I too was looking at a custom made unit from yorkshire pine as a few members on here have had them made and they look great, not sure which route to go though as the blok is just about perfect (apart from the price!!!)
Old 26-09-2008, 5:29 PM   #20
7,549, Level: 20
For info,
Looked again at the BloK. Here is an extract from an e-mail I have just received from Blok UK...
"We are only making these cabinets to order now as we have a new range taking over late October.
Due to the higher cost from getting these made in the UK we can only sell these items direct and not through a re seller."
Old 01-03-2009, 2:31 PM   #21
1,798, Level: 9
Points: 1,798, Level: 9 Points: 1,798, Level: 9 Points: 1,798, Level: 9
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 7, Got 0
Just stumbled across this post. So sorry if its a bit out of date but if you are still interested then they are selling the Blok 300 at av4home for £659.00.
Blok 3000 - Real Oak Veneer TV / AV Cabinet Furniture
I got one about 2 years ago. Its a very nice piece of furniture and although expensive it will see you through many years without appearing dated. Also they are fantastic for all your AV equipment as they are all open at the back to allow all the air flow you'll need.
Old 01-03-2009, 3:37 PM   #22
7,549, Level: 20
Nice of you to point this out. Trouble is, Blok have changed the design. The new one is narrower and will only accept a centre speaker mounted on its side.
I've decided that the only way I'll get what I really want is to have one custom made (or make one myself) but it's a bit low on my list of priorities at the moment. Thanks anyway.
Old 04-03-2009, 11:01 PM   #23
thudspud's Avatar
5,619, Level: 17
Gettting very confused about the blok 3000, the one you mention with the vertical centre speaker section was the orignal design from quite a few years ago and they recently replaced it with the (in my opinion) much nicer version with the horizontal centre speaker section with draw underneath but now it looks like they have stopped that as a lot of places are listing it as discontinued and the blok website says 'the classic blok cabinet is back" and shows a picture of the original design.
I hope the haven't stopped the updated version completely as it is the only cabinet I have ever seen that fits all of my equipment in that I actually like the look of!
Old 05-03-2009, 8:24 PM   #24
7,549, Level: 20
I can confirm that the latest offering is like the original. That is to say that the original had space only for a vertical centre, then the design was changed so that it would accept a horizontal centre with drawer underneath (this is what I wanted), now they have changed it back to be more like the original which won't take a horizontal centre and has no drawer. It is cheaper but smaller.
Blok is now part of Audini. I did speak to someone at Blok/Audini and they offered to make me one to the "wider with centre drawer" design. I was put off by the fact that they wanted 100% payment up front with a lead time of 6 to 8 weeks. In the current climate, with many businesses going bust, parting with all that money up front, makes me too nervous. I suggested 30% but the guy was adament. 100% up front or no deal, so I took the "no deal" option.
Old 08-03-2009, 12:36 PM   #25
3,142, Level: 13
Points: 3,142, Level: 13 Points: 3,142, Level: 13 Points: 3,142, Level: 13
Thanks: Gave 1, Got 0
I had Audini make the 3000 series with the draw and horizontal centre speaker placement in custom maple for me and it arrived just before Christmas.
Gave a 50% deposit and 50% when ready for delivery. I paid £750 for it.
Old 08-03-2009, 4:05 PM   #26
7,549, Level: 20
That's a far better deal than I was quoted. I know it's a cheek but could you perhaps PM me with details of who you spoke to? Also, are you happy with it?
Old 27-06-2009, 12:35 PM   #27
7,549, Level: 20
Resurecting a very old thread but if anyone is interested, just bought an original Blok 3000 (oak with black glass doors) from AV4home. They have some of the older, larger, units still in stock, as well as the newer smaller model. Bargain price too (well compared to what they used to sell for).
Old 05-08-2009, 10:07 AM   #28
4,436, Level: 15
Points: 4,436, Level: 15 Points: 4,436, Level: 15 Points: 4,436, Level: 15
Thanks: Gave 12, Got 30
Has anyone got a picture and/or dimensions of this intermediate version (Horizontal center + drawer) of the Blok 3000?
Thanks,
pingu.
Old 05-08-2009, 12:25 PM   #29
3,135, Level: 13
Points: 3,135, Level: 13 Points: 3,135, Level: 13 Points: 3,135, Level: 13
Thanks: Gave 2, Got 0
Just looking at the same!
I'm after a blok 3000 with horizontal speaker cab. Seen a very cheap one [well up for auction anyway!] on Ebay today, but it's got the wooden doors instead of the glass doors...and there's a reserve.
It's also on Amazon for £500 and looks like a clearance item from blok themselves. Have just been to their website but no pictures of this model, although they still have the vert speaker 3000 under blok "classix".
Can't find the horizontal speaker with glass doors anywhere else. Let me know if you see one.
Old 05-08-2009, 12:38 PM   #30
4,436, Level: 15
Thanks for the pointers!
Ewww! Don't like the whole sloping sides thing on top (I want to wall mount the TV) - maybe the classix would be better for me.
