Need help finding stand
Old 22-04-2008, 6:09 PM   #1
2,312, Level: 11
Points: 2,312, Level: 11 Points: 2,312, Level: 11 Points: 2,312, Level: 11
Thanks: Gave 8, Got 0
Hi all, im fairly new to this forum using it to help me in my recent upgrade obsession's
So her is my problem. I have just pre-ordered the new onkyo 606, and recently bought new ps3. With these new items my present stand is no good. So im looking for a stand that can house - onkyo amp, cd player, ps3, sky box and b&w cc6 s2.
Having looked at all the stands that people are recomending, i cant understand where my centre speaker would sit? Most of these stands just have two shelves, and putting the speaker in the middle of the top shelf just leaves one shelf for all my other components
Looking for any and all advice on what my best options would be. Which stand, or combination of stands should i go for? Many thanks Steve
Old 22-04-2008, 6:12 PM   #2
sbowler's Avatar
11,173, Level: 25
Points: 11,173, Level: 25 Points: 11,173, Level: 25 Points: 11,173, Level: 25
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 131, Got 497
Re: Need help finding stand
Have a walk around your local Ikea, some very useful furniture/stands in there. Argos also much underated.
jackiebrown (24-04-2008)
Old 23-04-2008, 10:04 PM   #3
2,833, Level: 12
Points: 2,833, Level: 12 Points: 2,833, Level: 12 Points: 2,833, Level: 12
Thanks: Gave 0, Got 4
Hi there,
I am having the same problem, as it is, my VCR sits on my lower shelf with my middle speaker on top of it, and my dvd recorder is on the second shelf with my Sky HD box on top of it, now I want to get a Blu Ray player, but I have no where for it to go. This does not even include my Wii!!
I have found a Sound Style WG4, but it says that it is for Hi Fis only, but I noticed that the WG3 (for HiFi/LCD), has one less shelf, but can carry the same load (60kg), as the WG4, but for some reason, the WG4 does not seem to be recommended for LCDs as well!?!?
I am very keen for any suggestions.
I have a SONY VCR SLV850; Sony DVD Recorder; Sky HD Box; Nintendo Gamecube; Wii; Pioneer Home Theatre System and KDL40W2000.
Old 24-04-2008, 3:32 PM   #4
2,312, Level: 11
Thanks for both your comments.......i am looking to spend a bit of money to get this right, so as i said any suggestions from all you home cinema freaks would be most welcomed.
I would imagine accommodating all the equipment is quite a common problem
Old 24-04-2008, 4:45 PM   #5
Knightshade's Avatar
11,666, Level: 25
Points: 11,666, Level: 25 Points: 11,666, Level: 25 Points: 11,666, Level: 25
Thanks: Gave 13, Got 51
Do you have a budget in mind?
Old 24-04-2008, 8:46 PM   #6
2,312, Level: 11
can only really afford about £200, so something second would be ideal.....though im sure £200could get s something half decent new
Old 24-04-2008, 9:16 PM   #7
vex vex is offline
10,368, Level: 24
Points: 10,368, Level: 24 Points: 10,368, Level: 24 Points: 10,368, Level: 24
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 27, Got 252
Have you tried Home Cinema Stands? they are an advertiser here and offer a very wide range.
iirc www.homecinemastands.co.uk will get you there.
V.
jackiebrown (27-04-2008)
Old 26-04-2008, 2:26 PM   #8
Conspicuous Member
chelsea.tone's Avatar
18,833, Level: 33
Points: 18,833, Level: 33 Points: 18,833, Level: 33 Points: 18,833, Level: 33
Thanks: Gave 792, Got 982
Hi, try this. Bought one myself, as i had problems finding something to house my 875 This ticks ALL boxes, superb stand
http://www.av4home.co.uk/cgi-bin/ss0...26&search.y=11
Ask for Mike if you contact them, very helpful.
Tony
Old 27-04-2008, 6:39 AM   #9
2,312, Level: 11
Thanks for your posts to the two above. However, as i explained my problem with these two recomendations is that from what i can see all these stands make no room for a big centre speaker placed under the tv.......because if you were to do so, there would be no room for all the other components.
So my question was not only looking for recomendation on a piece of furniturre, but also how other members with lots of home cinema items fit all theirs onto a stand
Old 27-04-2008, 11:32 AM   #10
Illustrious Member
signs's Avatar
30,704, Level: 42
Points: 30,704, Level: 42 Points: 30,704, Level: 42 Points: 30,704, Level: 42
Activity: 42.0%
Activity: 42.0% Activity: 42.0% Activity: 42.0%
Thanks: Gave 1,187, Got 2,119
With regards to your centre speaker ,i made this
and one with the new TV
Works fine
Old 27-04-2008, 7:51 PM   #11
11,666, Level: 25
May be worth having a look at Partington stands. Also I think Atacama do a couple of av type stands. Try http://www.audiophilecandy.com/home.asp for second hand stands.
Old 27-04-2008, 9:34 PM   #12
2,833, Level: 12
Hi all, me again. I have found what will be ideal, if we can get it at a good price.
Let me know what you think??
I
http://astore.amazon.co.uk/videophil...957295-8949251
Old 27-04-2008, 11:50 PM   #13
2,833, Level: 12
I am very tempted to get one of the ones in the links below: http://www.richersounds.com/showprod...IXE-PXHS30-BLK
or
http://www.amazon.co.uk/Centurion-Sh.../dp/B000QIO3YA
I know they are mainly for Hi Fis, but they have all the shelves I need, and it can definately more than support the weight of my 40" LCD, and the other equipment, plus it is a decent price. My main concern is, do you think it will tilt over and fall??
There is also this one:
http://www.amazon.co.uk/Centurion-Bl.../dp/B000VPDVVO
I have seen some others, but they are so pricey it is ridiculous, I even saw a perfect one, but it was £1,999.99 can you imagine???
I
