Wall mounted AV rack, recommendation please
Old 21-04-2008, 2:18 PM   #1
4,446, Level: 15
Points: 4,446, Level: 15 Points: 4,446, Level: 15 Points: 4,446, Level: 15
Thanks: Gave 6, Got 17
Looking for a wall mounted AV rack to bolt to brick wall.
Doesn't have to be sexy, classy or match my Playstation just functional and strong with easy access to cables. Laptop will be on top shelf with screen open and accessable keyboard, followed by consoles, dvd player and amp on other shelves. Happy to do self build if anyone wants to share design
Old 23-04-2008, 9:50 PM   #2
Assured Advertiser
8,384, Level: 21
Points: 8,384, Level: 21 Points: 8,384, Level: 21 Points: 8,384, Level: 21
Activity: 4.5%
Activity: 4.5% Activity: 4.5% Activity: 4.5%
Thanks: Gave 28, Got 237
Re: Wall mounted AV rack, recommendation please
Any idea on price? Vogels do a nice one with up to 3 or 4 shelves depending on which column you go for:-
http://www.quantumelectronics.co.uk/...-brackets.html
Old 30-04-2008, 10:16 AM   #3
100%WHU's Avatar
5,573, Level: 17
Points: 5,573, Level: 17 Points: 5,573, Level: 17 Points: 5,573, Level: 17
Thanks: Gave 24, Got 11
I looked at the Vogels, it looks great, but my concern is I have a Yamaha amp which weighs about 11kg and is 393cm depth. The Vogel wall mounts says max weight 10kg and 350 depth!
