Cooling For Enclosed Alphason Cabinet
Old 11-04-2008, 9:28 PM   #1
y2k y2k is offline
y2k's Avatar
5,011, Level: 16
Points: 5,011, Level: 16 Points: 5,011, Level: 16 Points: 5,011, Level: 16
Thanks: Gave 244, Got 295
Just added a couple of fans to my cabinet because things were getting a bit on the hot side, I will add a few pictures I took mith my phone and add the lnks for the stuff I used.
AC Power Adapter with Molex and SATA Power plugs http://linitx.com/viewproduct.php?prodid=12007
Sata to molex power adapter for the other fan http://linitx.com/viewproduct.php?prodid=11865
2X akasa 120mm ultra quiet case fans http://www.ebuyer.com/product/97858
Got 2 fan filters from maplin for 120mm for £4:99 but they are not on the website for some reason http://www.maplin.co.uk/Search.aspx?...source=15&SD=Y
7 piece hole set from argos, I used the second biggest hole with my drill http://www.argos.co.uk/webapp/wcs/st...0tools|9554865
And 8 screws from B&Q that are a bit longer than the ones that came with the fan.
The sata and molex lead is handy because it has an on/off switch for each fan/device on the lead. I will post the pictures because I dont think I would need to explain how to do it. I have watched 1 film so far with the fans on and its a lot cooler than it was before when I was just leaving the doors open .
I will add pictures tomorrow if I can because I have just seen the ones I was going to add and they are rubbish.
Cooling For Enclosed Alphason Cabinet-dsc00102.jpg   Cooling For Enclosed Alphason Cabinet-back-cabinet-when-finished.jpg   Cooling For Enclosed Alphason Cabinet-front-inside-cabinet-when-finished.jpg   Cooling For Enclosed Alphason Cabinet-finished-cabinet-doors-closed.jpg
Old 13-04-2008, 11:08 AM   #2
3,048, Level: 12
Points: 3,048, Level: 12 Points: 3,048, Level: 12 Points: 3,048, Level: 12
Thanks: Gave 9, Got 8
Re: Cooling For Enclosed Alphason Cabinet
Morning
This forum http://www.avforums.com/forums/av-stands-cabinets-seating-furniture/ might be better
Lots more cabinet cooling chat in there
Sam
Old 13-04-2008, 12:26 PM   #3
y2k y2k is offline
y2k's Avatar
5,011, Level: 16
Originally Posted by samuelhon View Post
Morning
This forum http://www.avforums.com/forums/forumdisplay.php?f=129 might be better
Sam
Cheers for that, I posted here because this is the part of the site that I was searching for some ideas on how to do this this, no wonder I didnt find to many ideas.
Updated the bottom 3 pictures, mabey a mod could move if this is in the wrong part of the site.
Old 13-04-2008, 7:49 PM   #4
inzaman's Avatar
22,352, Level: 36
Points: 22,352, Level: 36 Points: 22,352, Level: 36 Points: 22,352, Level: 36
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 126, Got 543
Moved for you
