Plasma TV unit for 42" and 10-15(!) components
Old 09-04-2008, 9:09 AM   #1
3,439, Level: 13
Points: 3,439, Level: 13 Points: 3,439, Level: 13 Points: 3,439, Level: 13
Forgive me if this is an oft discussed topic but as you might imagine my searches are turning up lots of units but not many big enough to fit on the amount of gear I need.
We have a room at work where we'll need to have a 42" Panasonic plasma with a DVD, VHS, and 2 or 3 of pretty much every console on the market at present (so PS3, 360, Wii, PS2 etc).
Presently we have a small trolley unit and have to keep moving stuff around / disconnecting stuff etc and it quickly turns into a cable nightmare.
Any suggestions as to where I might look for large AV units (not glass if we can avoid it!) that might do the job?
Cheers!
Old 09-04-2008, 1:12 PM   #2
1,719, Level: 9
Points: 1,719, Level: 9 Points: 1,719, Level: 9 Points: 1,719, Level: 9
Thanks: Gave 1, Got 8
Re: Plasma TV unit for 42" and 10-15(!) components
Hi, I think you will find it hard to get one stand/cab to house all that lot! Why dont you look at buying 3 stands/cabs? One for the Tv and the other 2 could sit either side of the Tv and house all of your kit.
