Wooden/dark stand??
Old 08-04-2008, 4:28 PM   #1
3,160, Level: 13
Points: 3,160, Level: 13 Points: 3,160, Level: 13 Points: 3,160, Level: 13
Wooden/dark stand??
Anyone able to recommend a stand for a sony40x.......
my room is quite old, original parquet flooring etc, so I'm looking either for something that will match the old style wood....or the tv itself.
Any ideas people?
Old 08-04-2008, 5:57 PM   #2
Knightshade's Avatar
11,666, Level: 25
Points: 11,666, Level: 25 Points: 11,666, Level: 25 Points: 11,666, Level: 25
Thanks: Gave 13, Got 51
Re: Wooden/dark stand??
How about these?
Wooden/dark stand??-av-unit.jpg   Wooden/dark stand??-oakstainedrack.jpg
Old 08-04-2008, 10:50 PM   #3
12,192, Level: 26
Points: 12,192, Level: 26 Points: 12,192, Level: 26 Points: 12,192, Level: 26
Thanks: Gave 1,130, Got 518
What about the ABR-1100 in Walnut ?
Old 09-04-2008, 5:30 PM   #4
3,160, Level: 13
Thanks both of you.
The first 2 are a little light for the floor I have, it's a bit darker and would like it to go with the floor if possible.
I'm going to have a look at the ABR in a bit more depth as think it would be a good height.
Thanks for suggestions anyway.
Old 16-05-2008, 7:08 PM   #5
4,973, Level: 16
Points: 4,973, Level: 16 Points: 4,973, Level: 16 Points: 4,973, Level: 16
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 83, Got 168
Just found this section on the forum
try
http://www.raspberryvillage.co.uk/
See shop on
http://www.raspberryvillage.co.uk/products/home.html
just search using tv keyword.
Old 02-06-2008, 5:59 PM   #6
Drunken Master's Avatar
6,466, Level: 19
Points: 6,466, Level: 19 Points: 6,466, Level: 19 Points: 6,466, Level: 19
Thanks: Gave 12, Got 8
I've got one of these...
http://www.standanddeliver.com/acata...00_walnut.html
